Concavity and the 2nd Derivative Test: Finding Maximum Deflection
4 replies · 6K views
karush
MHB
this is a problem in the topic of Concavity and the second Derivative Test
The deflection $$D$$ of a beam of length $$L$$ is
$$D=2x^4-5Lx^3+3L^2x^2$$,
where $$x$$ is the distance from one end of the beam.
Find the value of $$x$$ that yields the maximum deflection
The answer to this is $$x=\Bigg(\frac{15-\sqrt{33}}{16}\Bigg)L \approx 0.578L$$
well first of all this equation has 2 variables in x and L so not sure what to do perhaps implicit differentiation. also the answer looks it came from a quadratic formula
so not to sure what the first step is.
Re: beam deflection
The length of the beam $L$ is a constant.
So what you want to do is compute $D'(x)$ to determine the critical values in the range:
$$[0,L]$$
and then evaluate $D''(x)$ at these critical values, looking for negative values, i.e., concave down, and hence a maximum.
Can you proceed?
Re: beam deflection
L is not a variable its a constant as length is constant and hence you can go for first derivative which is equal to slope.it is maximum when tangent comes parallel to x-axis so = '0' and proceed, you might have mistook L as variable
Re: beam deflection
$$D'=8x^3-15Lx^2+6L^2x$$
$$=x(8x^2-15Lx+6)=0$$
so $$x=0$$
or $$\frac{15L\pm \sqrt{33}L}{16}$$
$$=\left(\frac{15 \pm \sqrt{33}}{16}\right) L$$
$$=0.5784L$$ or $$1.2965L$$
so $$D'' = 24x^2-30Lx+6L^2$$
$$D''(0.5784L)>0 $$ so max is $$0.5784L$$
Yes, good work! (Yes)
You can discard the critical value that is greater than $L$, since this is outside the relevant domain of $$x\in[0,L]$$.
