Conditional probability with marginal and joint density
6 replies · 2K views
Linder88
Determine ##P(X<Y|x>0)##
X and Y are random variables with the joint density function
f_{XY}(x,y)=
\begin{cases}
4|xy|,-y<x<y,0<y<1\\
0,elsewhere
\end{cases}$$
The marginal densities are given by
f_X(x)=2x\\
f_Y(y)=4y^3
The formula for conditional probability is
P(B|A)=\frac{P(B\cap A)}{P(A)}
In this case we have
P(X<Y|x>0)=\frac{P(X<Y\cap x>0)}{P(x>0)}=\frac{F_{XY}(x,y)}{F_X(x)}=\frac{\int_{}4|xy|dxdy}{\int_0^{\infty}2xdx}
This is where I get stuck, I do not know what boundaries I should put for the joint density function, can someone please help me?
f_{XY}(x,y)=
\begin{cases}
0,elsewhere
\end{cases}$$
f_X(x)=2x\\
f_Y(y)=4y^3
Draw the lines ##x=y##, ##x=-y##, ##y=0##, and ##y=1##. Shade the part where x and y are between the appropriate lines. The limits are just like in any double integral in calculus. Also, I didn't check your work but surely if the marginal density is ##2x##, it wouldn't be valid clear to ##\infty##.
f_{XY}(x,y)=
\begin{cases}
0,elsewhere
\end{cases}$$
f_X(x)=2x\\
f_Y(y)=4y^3
You claimed ##f_X(x) = 2x## cannot possibly be correct. In the sample space, ##x## is allowed to be both ##< 0## and ##>0##, and when ##x < 0## your formula delivers a negative probability.
The shaded area is a inverted triangle in the upper half of the plane with y vertical and x horizontal, so we have that
P(X<Y|x>0)=\frac{\int_0^1\int_{-y}^y4|xy|dxdy}{\int_0^12xdx}=\frac{1}{1}=1
I guess this concludes this topic, thanks :)
For the record: your final answer is correct, but you have computed ##f_X(x)## incorrectly. You should have gotten
[tex]f_X(x) = \frac{1}{2} |x| ( 1 - x^2),\; 0 \leq x \leq 1[/tex]
Unlike your answer, this has ##f_X > 0## for both ##-1 < x < 0## and ##0 < x < 1##.
Did you mean $$2*|x| ( 1 - x^2),\; 0 \leq x \leq 1\text{ ?}$$
