Conditions on random variable to satisfy limit property
The problem involves determining conditions on a random variable X such that its characteristic function g(t) satisfies a specific limit property as t approaches 0. The original poster assumes that X is symmetric around 0, leading to a real and even characteristic function.
  • Participants discuss the application of l'Hopital's rule to evaluate the limit and explore the implications of the characteristic function's properties. Questions arise regarding the value of g(0) and its relevance to the limit being evaluated.
The discussion is active, with participants exploring different cases based on the derivative of the characteristic function at zero. Some guidance has been provided regarding the evaluation of limits and the implications of symmetry in the random variable.
There is an assumption that the random variable X is symmetric around 0, which influences the evaluation of g'(0). Participants are considering the implications of this assumption on the limit and the necessary conditions for the problem.
jjhyun90
The problem is to find sufficient and preferably also necessary conditions on random variable X such that its characteristic function g(x) satisfies the limit property:
[itex]\lim_{t\to0}\frac{1-g(\lambda t)}{1-g(t)}=\lambda^2[/itex]
I may assume X is symmetric around 0, so the characteristic function is real and even.
[itex]g(t)=\int_{-\infty}^{\infty} e^{itx}f_{X}(x) dx[/itex]
I'm stuck immediately after trying to apply l'Hopital's rule. Any suggestions would be helpful.
Thank you.
What is the value of [itex]g(0)[/itex]?
[itex]g(0)=1[/itex] since it is a characteristic function.
So, what can you say about your limit? Can you evaluate it?
Using l'Hopital's rule and chain rule, the equivalent condition I need will be
[itex]\lim_{t\to0}\frac{g'(\lambda t)}{g'(t)} = \lambda[/itex].
Not really, evaluate these derivatives explicitly:
[tex] \frac{d}{d t} \left(1 - g(\lambda t)\right)[/tex]
[tex] \frac{d}{d t} \left(1 - g(t)\right)[/tex]
I must be confused. If I'm not mistaken, the first evaluates to [itex]-\lambda g'(\lambda t)[/itex] and the second [itex]-g'(t)[/itex].
True, so your limit becomes:
[tex] \lim_{t \rightarrow 0}{\frac{-\lambda g'(\lambda t)}{-g'(t)}} = \lambda \, \lim_{t \rightarrow}{\frac{g'(\lambda t)}{g'(t)}}[/tex]
Before you run in evaluating this limit, you need to consider two cases:
1) [itex]g'(0) \neq 0[/itex]. Then the limit is simply 1 and you get the result you posted in post #5. However, this is not what you have in the condition of the problem.
2) [itex]g'(0) = 0[/itex] What is the limit in this case?
BTW, what does [itex]g'(0)[/itex] mean?
The condition I posted on #5 is what I desire to have, rather than what will follow from the assumption. Sorry for the confusion.
By the assumption that X is symmetric around 0 and thus its expected value is 0, it follows g'(0)=0, so it is necessary to use l'Hopital's rule again.
Thus it seems a sufficient condition is that 0 < var(X) < infinity. Please let me know if I am wrong, but otherwise thank you for your help!
Yes, you are correct.
