Configuring the restoring force for a pendulum equation
  • Thread starter Thread starter outdoorjunkie
    Force Pendulum
The discussion focuses on understanding the approximation sinθ ≈ θ for small angles in pendulum motion, specifically when θ is less than π/10 radians (about 20 degrees). The user struggles with applying this approximation in the context of the restoring force equation, Fr = (w)θ. Through calculations, they find that the approximation holds true for small angles, as demonstrated by comparing values from Wolfram Alpha. The user realizes their error in applying the sine function and acknowledges that a Taylor series expansion shows the insignificance of higher-order terms for small angles. This clarification highlights the validity of the small angle approximation in physics.
outdoorjunkie
In order to configure the equation for the restoring force of a pendulum, my physics book uses this equation:
sinθ ≈ θ when the angle is less than π/10 (or about 20 degrees.) I've tried to figure this out on my calculator, but cannot figure out how they make this assumption.
The above equation is then put into Fr = (w)(sinθ) to create this equation:
Fr = (w)θ
Nothing, I have used radians and degrees to try to figure out how they get this equation, but I cannot. Thanks so much for your help!
π/10 ≈ .314 radians
sin(.314) ≈ .309
Seems pretty close to me. And it gets better for smaller angles.
Well, trying out some rad values at Wolfram Alpha gives me the following results:
sin(\pi /20)\approx 0,156 when
\pi/20 \approx 0,157
so I guess it is a valid approximation, at least it holds up to 2 decimals in this case.edit: You got me Doc Al!
Okay, now I understand. I was figuring the problem wrong, I was doing sin(π/10) instead of π/10 and then putting that answer into the sine. Thank you so much!
If you do a taylor series expansion of the sine function the second order term is proportional to the angle cubed. If the angle is in radians the term becomes insignificant for small angles.
Google "Taylor series" or "Small angle approximation" for more information :).
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 26 ·
  • · Replies 27 ·
19K
