Confused how to use calculus in physics
The discussion clarifies the application of calculus in physics, specifically in calculating electric fields from uniform charge distributions. The integral E_x=∫dEcosθ represents the summation of differential electric field contributions, where dE is a vector and cosθ projects it onto the x-axis. The integral signifies the need to express variables in terms of each other, facilitating the addition of contributions from an infinite number of charge points through superposition. Understanding this concept is crucial for effectively applying calculus in physics problems involving continuous charge distributions.
  • Understanding of basic calculus concepts, including integration and differentiation.
  • Familiarity with electric field concepts and vector projections.
  • Knowledge of superposition principle in physics.
  • Ability to interpret geometric relationships in physics problems.
  • Study the concept of vector fields in electromagnetism.
  • Learn about the application of line integrals in calculating electric fields.
  • Explore the principles of superposition in continuous charge distributions.
  • Investigate the geometric interpretation of integrals in physics contexts.
Students and professionals in physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify the integration of calculus in physical applications.
jaydnul
I understand simple concepts, like \frac{dx}{dt}=v and why that is, but when I'm doing, for example, uniform charge distributions, I don't understand what the integral is actually doing. For example:
E_x=∫dEcosθ
From what I learned in calculus, the dE means with respect to. So when taking an integral you usually have the form ∫y(x)dx and the interval is [a,b], which are x values.
Why isn't the integral above in that form then? I mean at the very least, ∫dθcosθ would make more sense to me.
Why isn't it in that form? Because you haven't made it into that form yet, that is your goal. You need to express E in terms of theta, or theta in terms of E, by looking at the geometry of the situation.
Every little point in a charge distribution contributes to the overall electric field. If you just had 2 point charges you would add the fields in accordance with superposition. But now that you have an infinite number of points in a larger distribution, you need to do an integral to add them all up.
Jd0g33,
∫ means a "sum" over differential amounts.
In ∫dE cosθ the differential amount is dE cosθ
dE is a vector and dE x cosθ is its projection on the x-axis.
Adding up all the projections of every dE, you get E_{x}.
When taking ∫y(x)dx, the differential amount being added up is y(x)dx, that is, y(x) times dx.
This is the "area" under the point y(x).
In this explanation, I have used some loose terms, but I hope I could pass the message.
  • · Replies 22 ·
  • · Replies 33 ·
  • · Replies 17 ·
10K
  • · Replies 26 ·
  • · Replies 16 ·
