Confusing Algebra problem help
In summary: C0 (original concentration) = 1mlCC0 = C0 x 10^(-n)CC0 = C0 x 10^(-n-1)CC0 = C0 x 10^(-n-2)etc. etc.So you can see that as you have more dilutions, the power of 10 increases. So for 5 dilutions, the concentration would be C0 x 10^(-5).In summary, the problem involves diluting a sample with a buffer to obtain a desired concentration. The resulting concentration is 1/10 of the original concentration after each dilution. To find the concentration after a certain number of dilutions, the formula C = C
misskitty
737
Ok, I have this word problem dealing with exponential growth and decay. I need serious help. There are three parts to this problem...I really need help with this.
Here's the problem:
A dilution is commonly used to obtain the desired concentration of a sample. For example, suppose that a 1 millilitre of hydrochloric acid, or HCl, is combined with 9 millilitres of a buffer. The concentration of the resulting mixture is 1/10 of the original concentration of HCl.
a.) Suppose that this dilution is performed again with 1 millilitre of the already diluted mixture and a 9 millilitre buffer. What is the concentration of the resulting mixture (compared with the original concentration)?
b.) Write an expression to model the concentration of HCl in the resulting mixture after repeating dilusions as described in part "a".
c.) What is the concentration of the resulting mixture (compared to the orginal concentration) after 5 repeated dilusions?
Ok, I don't even know what I'm supposed to find or how I'm supposed to find it. I tried this in class without any luck, unfortunately my calculations only took me as far as .1^.1. I don't even think that's right. Could someone please help me? I really need it. Thanks.
well I can't figure an answer right now, but it looks as though you will need to use [tex] y=mx^2+b[/tex]
Just out of curiosity, why would I use y=mx+b? I was following the amount x multiplier^to a power. I don't know what to do.
Here's the problem:
Well you can calculate the initial HCl concentration : molar mass HCl/volume in litre
Now after each dilusion, the initial concentration is divided by ten right?
Sow you would get something like : inital concentration is denoted by C0
concentration C = (C0)*(10)^(-n) where n denotes the number of dilusions
marlon
Ummm, right. :confused:
What I posted is what I've got for information. Would I divide the molar mass by 1000? I would assume each dilusion would be the intial concentration divided by 10. I don't understand the CO notation you're talking about. Wow, I suck at word problems! Thanks Marlon.
I mean my thank you seriously, it isn't ment to be sarcastic or deterrogatory. I really do suck at word problems. :frown:
Here's the problem:
You got your first concentration by multiplying a pure concentration (1) by .1 {1 ml divided by (1ml + 9ml)}.
You dilute the resulting concentration by the same amount, or you're multiplying .1 by .1.
In other words, you have concentration (C) of:
[tex]C = 1 * .1 * .1 * .1 ... [/tex] (You multiply by .1 each time you dilute it.
If you want to simplify it into a formula, you're multiplying 1 by [tex].1^n[/tex] where n states how many times you're performing the dilution. It's not .1, since you can't perform the dilution .1 times (unless you hear the phone ring as soon as you start to poor in the buffer, I guess).
I think accidently sniffing their chemicals must be an occupational hazard of being a chemist. Chemists are often 'dilusional'. :rofl:
Co just denotes the initial concentration that you calculate. the molar mass of elements is given in the tabel of Mendelejev
marlon
got it thanks
i just put in [tex]y=mx^2+b[/tex] just in case you had a calculator, that could then make the graph for you and determine the exponential decay, i spose the more proper way to show it would be [tex] y=mx^n [/tex]
Ah ok, I think I'm more graphing calculator illiterate than I am computer illiterate. :redface:
[itex] x^{n} [/itex] is not exponential decay!.
Notice for each dilution your initial dilution D is decreasing by a power of 10
Original concentration = 1ml (100%)
First dilution -> 0.1ml (10%)
Second dilution -> 0.01ml (1%)
nth Diltuion -> D x 10^(-n)
Concentration C is proportional to original dilution D and inversely proportional to 10 raised to the number of dilutions
C = D/(10^n)
So for 5 dilutions you would have C = D/10^5, where D = 1ml
C = 0.00001ml or 1 x 10^-5 ml
Whozum, thanks! I just worked out your formula with the data and checked the answer in the back of the book, its correct. Thanks for the help everyone! :biggrin:
1. What is an algebra problem?
An algebra problem is a mathematical equation or expression that contains one or more variables and requires solving for one or more unknown values.
2. Why are algebra problems confusing?
Algebra problems can be confusing because they often involve multiple steps and require a solid understanding of mathematical concepts and rules. They may also involve abstract thinking, which can be challenging for some people.
3. How can I approach a confusing algebra problem?
One approach to solving a confusing algebra problem is to break it down into smaller, simpler steps. Make sure to carefully read and understand the problem, identify the known and unknown values, and use algebraic rules and techniques to solve for the unknowns.
4. What are some common mistakes to avoid when solving algebra problems?
Some common mistakes to avoid when solving algebra problems include: not carefully reading the problem, using incorrect order of operations, forgetting to distribute or combine like terms, and making calculation errors.
5. Where can I find help with confusing algebra problems?
You can find help with confusing algebra problems from various sources, such as textbooks, online resources, tutors, or teachers. It can also be helpful to practice regularly and ask for clarification when needed.
  • Biology and Chemistry Homework Help
