Confusing expression in a paper
7 replies · 2K views
natski
Hi all,
Whilst reading http://www.jhuapl.edu/techdigest/td1703/thomas.pdf I found one of the equations a little difficult to interpret. On page 3, there is a function defined as f. On the denominator there it appears that they have differentiated n(z''(Z')) as a function of z'' and then evaluated it for the case where Z' goes to Zi'.
As far as I can tell, n is only a function of z'' and z'' is not a function of anything else, so the n(z''(Z')) doesn't make much sense to me. I interpretted it as meaning that I write down the expression n(z'') then replace all my z'' s with Z' using an appropriate equation of the form:
Z'=some function of z''.
However, I cannot even write down a clean expression for this! The form of Z', as seen just below eqn 4, cannot be easily rewritten to express z'' as a function of a Z'.
Can anyone help me interpretting this confusing expression?
Thanks!
Mathematics news on Phys.org
Reading the text above equation (4), it appears that Z'(z'') originates from a "simple variable substitution" which they then detail, below equation (4).
Yes you are right but when I tried to rewrite Z'(z'') as z''(Z') I could not and it seemed to require solving in some kind of non-algebraic way.
The only true occurrence of z'' is in the denominator, just supress n(z'') to n.
What do you mean suppress? n(z'') is quite a complex function of z''.
What I meant was to differentiate implicitly.
Umm ok, so I can write:
z''=[n(h) (R+h) Cos(Delta)]/(n(z'') Z') - R
Then are you thinking I should replace all my z''s in n(z'') with this equation? If I do this, I can't differentiate by z'' since now I have got Z' in there too.
I think I should differentiate first n(z'') by z'' first since that's not too hard. I then need to replace z'' with the equation above. However, when I then replace Z' with Zi' I still have z'' floating about which I can't get rid off!
Differentiating implicity or using some kind of chain rule or anything will not make life any easier as far as I can tell. The differentation part is the one part that is easily done, it's the replacing z''->Z'->Zi' that's the problem.
