Confusing Stoichiometry Question
The discussion centers on a stoichiometry problem involving the reaction of potassium permanganate (KMnO4) and hydrochloric acid (HCl) to produce chlorine gas (Cl2). For part A, the correct mass of KMnO4 required to produce 2.5 L of Cl2 gas at STP is calculated to be 7.05 g. In part B, participants are tasked with determining the volume of 36.0% commercial hydrochloric acid needed, given its density of 1.18 g/mL. The importance of validating numerical answers against expected orders of magnitude is emphasized, particularly through the application of the ideal gas law.
  • Understanding of stoichiometry and chemical reactions
  • Knowledge of the ideal gas law
  • Familiarity with concentration calculations (mass percent)
  • Basic skills in unit conversion and density calculations
  • Calculate the required mass of HCl using stoichiometric ratios
  • Learn about the ideal gas law and its applications in stoichiometry
  • Explore density and concentration conversions for solutions
  • Review common pitfalls in stoichiometric calculations
Chemistry students, educators, and anyone involved in chemical engineering or laboratory work who seeks to enhance their understanding of stoichiometry and gas laws.
pure kirk
I got this question as an example question and I have no clue on how to solve part B
Chlorine can be produced by the reaction:
2KMnO4 + 16HCl ->2KCl + 2MnCl2 + 5Cl2 + 8H2O
(a)What mass of KMnO4 is required to produce 2.5 L of Cl2 gas measured at STP?
For part A I got 7.05 g ( 0.044615 moll)
(b) Calculate the volume of commercial hydrochloric acid required (Commercial grade hydrochloric acid is 36.0% HCl by weight, and has a density of 1.18 g mL^(–1)).
Chemistry news on Phys.org
That is much too low. Please show your calculations.
Can you start by figuring what mass of HCl you need?
I got 7.051 g as well:
I'm sorry for the mistake. I used the density of Cl2 given by WolframAlpha, which is much higher.
Looks like they are listing density of a liquid Cl2 - which doesn't make much sense at STP...
Indeed. Very strange.
I feel ashamed because I didn't follow the rule that I always tell my students: when you get a numerical answer, always try to figure out if the order of magnitude makes sense. I should've checked with the ideal gas law...
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
  • · Replies 17 ·
  • · Replies 23 ·
11K
10K
11K
