Confusion about calculating energy output.
The discussion focuses on calculating the energy output of a laser for comparison with the energy required to make tea. The Nova laser delivers a power of 1.60 × 10^13 W over a time interval of 2.50 ns. Participants clarify that power in watts is defined as joules per second, and to find total energy output, one must multiply power by time. The calculations yield different results depending on the method used, with the correct approach being to multiply the power by the time interval to obtain total energy in joules. Understanding these calculations helps contextualize the energy produced by the laser in practical terms.
srarahcha
I have a question that involves comparing the energy output of a laser to the energy required to make tea. I've already calculated the energy to make tea and I know what to do to find how long it takes to make the tea but I'm struggling with the energy output part.
It says: The Nova laser at Lawrence Livermore National Laboratory in California is used in studies of initiating controlled nuclear fusion . It can deliver a power of 1.60 × 1013 W over a time interval of 2.50 ns.
The attempt at a solution
So initially I multiplied the W by the ns (converted to s) to find the Watts over an interval of 1 second but idk if that worked... then I divided it instead but I don't think that's right either... Now I'm going to try just substituting the nanoseconds and the watts into an equation to find the time and see if it works! But I'm still quite confused.
What numbers have you got from your calculation?
Analyze the units involved. What's the definition of a Watt?
So when I multiplied it, i got 40000J. When I divided instead, I got 6.4x10^21.
so I just thought about how power (Watts) is Joules over a specific time interval... so if the Power is 1.60 x 1013Watts over a 2.50 ns interval, and P=J/Δt, then if I rearrange the equation to 1.60 x 1013 W * 2.50 x 10-9 s = Joules, i would also get the joules/second (aka Watts with a time interval of 1 s) because Joules over 1 second is the same number...
One Watt is one Joule per second: 1 W = 1 J/s. So if you multiply by a given time (such as your 2.50 ns) you get the total energy in Joules produced over that time interval. The result has the unit Joules. It's then up to you to interpret what that value means in the context of what you're trying to accomplish. For example, you now know how much energy you can get from a single firing of the laser.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
