Confusion about determining distribution of sum of two random variables
  • Thread starter Thread starter psie
    Probability theory
The discussion revolves around determining the probability density function (pdf) of the sum of two independent random variables, ##X## and ##Y##, where ##X## is uniformly distributed over (0,1) and ##Y## is uniformly distributed over (0,α). Participants are examining the implications of the problem statement that suggests two cases based on the value of α.
  • Participants explore the convolution of the two density functions and the conditions under which they are non-zero. There is a focus on the inequalities that define the limits of integration for the pdf of the sum, ##f_Z(z)##. Some participants question the necessity of considering multiple cases based on the value of α, while others express confusion about specific values of ##z## leading to negative densities.
The discussion is ongoing, with participants raising questions about the validity of certain cases and the implications of the derived expressions. There is recognition that the expression for ##f_Z(z)## could be defined as zero outside the interval (0, 1+α), but the need for clarity on the case distinctions remains a point of contention.
Participants note that the problem statement explicitly mentions two cases based on the value of α (≥1 and <1), which is a source of confusion. There is also a concern about the interpretation of the density function when ##z## takes on values outside the expected range.
psie
Let ##X## and ##Y## be independent r.v. such that ##X\in U(0,1)## and ##Y\in U(0,\alpha)##. Find the density function of ##Z=X+Y##. Remark: Note that there are two cases: ##\alpha\geq 1## and ##\alpha <1##.
The relevant equation is that the pdf of the sum of two continuous random variables is a convolution.
Let's recall the densities of ##X## and ##Y##:
\begin{align}
f_X(x)=\mathbf{1}_{(0,1)}(x), \quad f_Y(y)=\frac{1}{\alpha}\mathbf{1}_{(0,\alpha)}(y)
\end{align}
Let ##z\in (0,1+\alpha)##. So we know that ##f_Z(z)## is given by:
\begin{align}
f_Z(z)=\int_\mathbb{R} f_X(t)f_Y(z-t)\,dt
\end{align}
Both ##f_X## and ##f_Y## are zero most of the time. We check ##f_X## and ##f_Y## one by one. We start with ##f_X(t)##; it is nonzero when ##0<t<1##. We have that ##f_Y(z-t)## is nonzero when ##0<z-t<\alpha##. That means ##t<z## and ##z-\alpha<t##. We want to satisfy all these inequality at once. So that means ##\max\{z-\alpha,0\}<t<\min\{1,z\}##. Hence:
\begin{align*}
f_Z(z)=\int_{\mathbb{R}}f_X(t)f_Y(z-t)\,dt=\int^{\min\{1,z\}}_{\max\{z-\alpha,0\}}\frac{1}{\alpha}\,dt=\frac{\min\{1,z\}- \max\{z-\alpha,0\}}{\alpha}
\end{align*}
Now, what troubles me is the remark in the problem statement. I don't see that there are two cases to consider. For me, the density is simply the one given in the last equation, or?
Consider the case ##\alpha = 1## and ##z = -1##. Your function would be
f_Z(-1) = \min(1,-1) - \max(-1-1,0) = -1 - 0 = -1.
Is this reasonable?
psie said:
Homework Statement: Let ##X## and ##Y## be independent r.v. such that ##X\in U(0,1)## and ##Y\in U(0,\alpha)##. Find the density function of ##Z=X+Y##. Remark: Note that there are two cases: ##\alpha\geq 1## and ##\alpha <1##.
Relevant Equations: The relevant equation is that the pdf of the sum of two continuous random variables is a convolution.
\begin{align}
\end{align}
\begin{align}
\end{align}
\begin{align*}
\end{align*}
Nitpick: Convolutionof _Independent_ Random Variables.
Is this reasonable?
How can ##z=-1##? If ##\alpha=1##, then ##z\in (0,2)##, no?
Exactly. The distribution should be zero there. Your expression is not only non-zero, but negative.
Ok. But couldn’t we simply say that the expression for ##f_Z(z)## I gave is the distribution for ##z\in (0,1+\alpha)## and ##0## otherwise?
Sure, but that is still kind of breaking it up into cases. So is using the min/max functions.
  • · Replies 19 ·
