Explaining Connected Component: Real Numbers, Rationals, & More
  • Thread starter Thread starter rainwyz0706
    Component
The discussion clarifies the concept of connected components in topology, emphasizing that a connected component is the largest connected subset containing a given point. It notes that the connected components of the real numbers (R) and rationals (Q) are singletons, while R itself is connected. The participants explore the topology of the set X = {(x, y) ∈ R² ; x ≠ y}, determining that it is disconnected by examining closures and intersections. They also discuss the implications of having an empty interior for subsets of R, identifying examples like Q and the Cantor set. Finally, the conversation touches on the connectedness of the set X = {(z, w) ∈ C² ; z ≠ w}, concluding that it is path connected and therefore connected.
rainwyz0706
I'm not quite clear about this notion. Could anyone explain a little bit for me?
Here is the definition:
Let a be an arbitrary point in X . Then there exists a largest connected subset of X
containing a, i.e. a set Ca such that:
• a ∈ Ca and Ca is connected;
• for any connected subset S of X containing a, S ⊆ Ca .
We call such a set Ca the connected component of X containing a, or simply a connected
component of X .
I can see that the connected components of R, Q etc are the singletons.
What about X = {(x, y) ∈ R2 ; x not equal to y} with the topology induced from R2 ?
Btw, if the interior of a subset A of R is the empty set, what are the different possibilities? Obviously, A could be Q, C, R etc.
Your input is greatly appreciated!
Ca is the largest/maximal connected subset containing a, meaning that if S contains a, and
S contains C, then S is not connected.
"I can see that the connected components of R, Q etc are the singletons. "
Q, as a subset of R, is totally disconnected, so that the singletons q_n are the components. Any larger (than {q_n}, for any n ) subset containing q_n is disconnected.
(R , Std. Metric Topology)is connected, so the maximal connected subset containing
R is R itself.
"What about X = {(x, y) ∈ R2 ; x not equal to y} with the topology induced from R2 ?."
Then check to see if X is disconnected: what is the closure of X1={(x,y) in R^2 : x>y}
union X2={(x,y) in R^2: x<y}?. X is disconnected if ClX1/\X2 is empty,
and so is X1/\ClX2 (/\ is intersection, Cl is closure).
In the use I know, components are closed, since , if a subset A is connected, so is its
closure.
"Btw, if the interior of a subset A of R is the empty set, what are the different possibilities? Obviously, A could be Q, C, R etc."
R does not have empty interior. The Baire Category theorem shows this.
Q has empty interior --the irrationals are dense in the reals.
The Cantor set has empty interior
Thank you very much for your reply. I have a much clearer picture in my mind.
Just one more question, to find the connected component for X = {(z, w) ∈ C2 ; z not equal to w} with the topology induced from C2, we still need to check to see if X is disconnected right? But it's hard to find two open and disjoint sets whose union is X. Since z not equal to w only means that the real parts and the complex parts are not equal respectively. How do we treat it then? Again, I really appreciate all your input here.
I can't see, right away, a straightforward way to show that X=\{(z,w)\in\mathbb{C}^2\mid z\ne w\} can't be separated. However, it's not hard to see that it's path connected, implying that it's connected.
First notice that for any u,v,w in C, there's a path from u to v that avoids w (if this is not obvious, draw a picture). Use that to see that there's a path from (u,v) to (z,w) in X, for any choice of (u,v) and (z,w):
First, there's a path from (u,v) to (z,v) lying entirely in C x v which avoids (v,v), by the lemma above. Then, there's a path from (z,v) to (z,w) lying entirely in z x C which avoids (z,z) by the same reasoning. Concatenate the two and you've shown X is path connected, therefore connected.
