Explaining Connected Component: Real Numbers, Rationals, & More
  • Context: Graduate
  • Thread starter Thread starter rainwyz0706
    Component
The discussion focuses on the concept of connected components in topology, specifically regarding real numbers (R), rational numbers (Q), and complex numbers (C). It establishes that the connected components of R and Q are singletons, while R itself is connected. The conversation also explores the topology of the set X = {(x, y) ∈ R² ; x ≠ y} and its connectedness, concluding that it is disconnected. Additionally, it highlights that the Cantor set and Q have empty interiors, while R does not, referencing the Baire Category theorem.
  • Understanding of basic topology concepts, including connectedness and components.
  • Familiarity with real numbers (R), rational numbers (Q), and complex numbers (C).
  • Knowledge of the Baire Category theorem and its implications.
  • Ability to work with topological spaces and closures in R² and C².
  • Study the properties of connected spaces in topology.
  • Learn about the Baire Category theorem and its applications in real analysis.
  • Explore path-connectedness and its relationship with connectedness in topological spaces.
  • Investigate the topology of disconnected sets and their closures in R² and C².
Mathematicians, students of topology, and anyone interested in understanding the properties of connected components in various topological spaces.
rainwyz0706
I'm not quite clear about this notion. Could anyone explain a little bit for me?
Here is the definition:
Let a be an arbitrary point in X . Then there exists a largest connected subset of X
containing a, i.e. a set Ca such that:
• a ∈ Ca and Ca is connected;
• for any connected subset S of X containing a, S ⊆ Ca .
We call such a set Ca the connected component of X containing a, or simply a connected
component of X .
I can see that the connected components of R, Q etc are the singletons.
What about X = {(x, y) ∈ R2 ; x not equal to y} with the topology induced from R2 ?
Btw, if the interior of a subset A of R is the empty set, what are the different possibilities? Obviously, A could be Q, C, R etc.
Your input is greatly appreciated!
Ca is the largest/maximal connected subset containing a, meaning that if S contains a, and
S contains C, then S is not connected.
"I can see that the connected components of R, Q etc are the singletons. "
Q, as a subset of R, is totally disconnected, so that the singletons q_n are the components. Any larger (than {q_n}, for any n ) subset containing q_n is disconnected.
(R , Std. Metric Topology)is connected, so the maximal connected subset containing
R is R itself.
"What about X = {(x, y) ∈ R2 ; x not equal to y} with the topology induced from R2 ?."
Then check to see if X is disconnected: what is the closure of X1={(x,y) in R^2 : x>y}
union X2={(x,y) in R^2: x<y}?. X is disconnected if ClX1/\X2 is empty,
and so is X1/\ClX2 (/\ is intersection, Cl is closure).
In the use I know, components are closed, since , if a subset A is connected, so is its
closure.
"Btw, if the interior of a subset A of R is the empty set, what are the different possibilities? Obviously, A could be Q, C, R etc."
R does not have empty interior. The Baire Category theorem shows this.
Q has empty interior --the irrationals are dense in the reals.
The Cantor set has empty interior
Thank you very much for your reply. I have a much clearer picture in my mind.
Just one more question, to find the connected component for X = {(z, w) ∈ C2 ; z not equal to w} with the topology induced from C2, we still need to check to see if X is disconnected right? But it's hard to find two open and disjoint sets whose union is X. Since z not equal to w only means that the real parts and the complex parts are not equal respectively. How do we treat it then? Again, I really appreciate all your input here.
I can't see, right away, a straightforward way to show that X=\{(z,w)\in\mathbb{C}^2\mid z\ne w\} can't be separated. However, it's not hard to see that it's path connected, implying that it's connected.
First notice that for any u,v,w in C, there's a path from u to v that avoids w (if this is not obvious, draw a picture). Use that to see that there's a path from (u,v) to (z,w) in X, for any choice of (u,v) and (z,w):
First, there's a path from (u,v) to (z,v) lying entirely in C x v which avoids (v,v), by the lemma above. Then, there's a path from (z,v) to (z,w) lying entirely in z x C which avoids (z,z) by the same reasoning. Concatenate the two and you've shown X is path connected, therefore connected.
  • · Replies 80 ·
10K
12K
