Connecting Anaconda with Access Database using Pyodbc
  • Thread starter Thread starter WWGD
    Database
15 replies · 3K views
Homework Helper
TL;DR
Trying to connect Anaconda with Access Db using Pyodbc , getting 'EOL String
Hi All,
My goal is to access an Access Database from within Anaconda Jupyter and , in Jupyter, use Pyodbc to conduct dynamic queries against my database and do some plotting of the data in Access. My code is below, together with the error message
Error message is:
File "<ipython-input-6-eabb548dc75e>", line 3
conn = pyodbc.connect(r'Driver={Microsoft Access Driver (*.mdb, *.accdb)};DBQ ="C:\AccessDbFiles\BillsPyodbc.accdb")
SyntaxError: EOL while scanning string literal
Any ideas?
jedishrfu said:
I notice the close paren is red maybe you are missing a single quote character.
r’blah blah “blah” ‘
Thanks, will check out tmw, just left coffee shop.
Untitled47? How do you remember where anything is?
I have my own system until I learn. Maybe not the best but somehow works.
jedishrfu said:
A real programmer let's the computer tell them where they are.
?? Not sure I get it.
Have you ever used the pwd command in linux? or the date or time commands? or even better the uname -a command?
Each of these commands tells you something about where you are or when you are or what machine you're on and there are many others that tell things you might need to know.
Definitely not the best, and I doubt it would work over a longer time span than a week or two.
If you take a small amount of time now to come up with names for your programs and variables (recalling another thread of yours) that are indicative of what they will do, it will really pay dividends when you are looking for examples of specific techniques or are trying to understand what your code is doing when you or others look at it a month or more later.
Borg's comment wasn't about where the programmer was, but was instead a comment on using uninformative program names such as Untitled47.
jedishrfu said:
Thanks @Mark44 but I was responding to @WWGD who asked about my real programmer humor while awaiting if the single quote was the issue in his code which I think it was.
It wasn't clear that your reply referred back to what WWGD said. In the interim, Borg asked "How do you remember where anything is?" -- so your comment seemed to me to be a non sequitur.
makes this a cast iron certainty - the parser is telling you that it reached the end of the line before it reached the end of the string!
Somtimes error messages are not very helpful, but you should always read them in case they are :rolleyes:
jedishrfu said:
Thanks, that brought back nightmares of projects long ago using DB2 and related hardware/software issues of broken connections.
In case it helps, I am having a few of my own, with nightmares about odbc drivers.
It seems that Computus, ruler of IT world, granted me the miracle of conecting through named pipes to use sqlcmd. A complete blur; I have no clue how it came to happen.
