Conservation momentum using center of mass
The discussion focuses on the conservation of momentum using the center of mass frame of reference in a collision scenario involving a very massive object (m1) and a small mass (m2). The key conclusion is that the low-mass object recoils with a velocity of 2v after the collision, derived from the conservation of momentum and energy equations. The calculations confirm that in the center of mass frame, the small mass m2 behaves like a ball bouncing off a wall, resulting in a final velocity of 2v when observed from the original frame of reference.
  • Understanding of conservation of momentum
  • Familiarity with kinetic energy equations
  • Knowledge of center of mass frame of reference
  • Basic algebra for solving equations
  • Study the concept of center of mass in physics
  • Learn about elastic and inelastic collisions
  • Explore advanced momentum conservation problems
  • Review vector addition in collision scenarios
Physics students, educators, and anyone interested in understanding collision dynamics and momentum conservation principles.
ex81
A very massive object with a velocity "v" collides head-on with an object at rest whose mass is very small. no kinetic energy is converted into other forms. Prove that the low-mass object recoils with a velocity 2"v"
use the center-of-mass frame of reference.
p=mv
ke= 1/2mv^2
M1>m2
my book doesn't actually describe the center of mass frame of reference so I'm lost there. But trying to solve for it:
m1*v1=m1*v2+m2*2*v1
m1(v1-v2)= m2*2*v1
(v1-v2)m1/m2=2*v1
m1*v1 + m2*0= m1*v2+ m2*2*v1
m1*v1 = m1*v2+ m2*2*v1
m1*v1 - m2*2*v1 = m1*v2
v1(m1 - m2*2)/m1 = v2
conservation of energy
1/2*m1*(v1)^2 +1/2*m*0= 1/2*m1*(v2)^2 +1/2*m2*(2v1)^2
1/2*m1*(v1)^2 = 1/2*m1*(v2)^2 +1/2*m2*(2v1)^2
1/2*m1*(v1)^2 = 1/2*m1*(v1(m1 - m2*2)/m1)^2 +1/2*m2*(2v1)^2
m1*(v1)^2 = m1*(v1(m1 - m2*2)/m1)^2 +m2*(2v1)^2
0 = m1*(v1(m1 - m2*2)/m1)^2 +m2*(2v1)^2 - m1*(v1)^2
The words, "A very massive object" is code for: "it's so massive that nothing that happens in the problem will measurably affect its momentum".
In this case the initially moving object, m1, is that very massive object. As such it is essentially the center of mass of the objects comprising the system. So if you, the observer, were to take up a position sitting on that massive object and you constructed your coordinate axes there, your point of view would be from the center of mass frame of reference.
From that point of view the very massive object m1 is at rest. What's the initial velocity of m2 in that frame of reference?
Why couldn't my book have anything like that explanation...
M2 in this case would have the same velocity as the super massive object (m1) so -v1, so when it collides it becomes v1? I don't get the 2*v1, unless we are talking about the total change in vector. Which would make sense 1- to 1 is 2
You're almost there. You've determined that the velocity of m2, after collision, will be vV1 in the center-of-mass frame of reference; After all, it's just behaving like a ball bouncing off of a wall.
Now comes the "magic" that is the usefulness of the center of mass frame. If you now switch back to the original frame of reference mass m1 is observed to be still moving at velocity v1 (it is, after all, a "very massive object"!), but what velocity will m2 have? Remember, it's moving at speed v1 with respect to m1.
the velocity of M2 is now V1 for the center of mass reference point. But if we let that continue to go at v1 then the two vectors add V1+V1 = 2 *V1, or V2
:D
Woot! Thanks for the help :D
