Conservation of Angular Momentum
The discussion centers on the conservation of angular momentum in a system involving a 500-gram piece of putty and a 4 kg rotating solid disk with a radius of 3 meters. The initial angular velocity of the disk is 10.0 rad/s. The final angular velocity after the collision is calculated to be 8.52 rad/s. For the average force on the putty during its 15 ms collision with the disk, the calculated value is 713 N, derived using the impulse-momentum theorem.
  • Understanding of angular momentum and moment of inertia
  • Familiarity with the impulse-momentum theorem
  • Knowledge of converting angular velocity to linear velocity
  • Basic principles of rotational dynamics
  • Study the conservation of angular momentum in inelastic collisions
  • Learn about the impulse-momentum theorem in detail
  • Explore the relationship between angular and linear velocity
  • Investigate the calculation of forces during collisions in physics
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of angular momentum and collision analysis.
veronicak5678
A 500 gram piece of putty falls straight down and sticks to a 4 kg rotating solid disk below. The uniform disk has a radius of 3 meters, and the putty hits the disk 2.5 meters from its center. You may neglect all forces other than that of the collision.
a- If the disk was initially rotating at 10.0 rad/s, find its final angular velocity.
b- The putty takes 15 ms to collide with the disk. Calculate the avergae force on the putty.
I = mr^2 and .5 mr^2, L = I omega
For part a,
I found moment of inertia of the disk (I_d) = 1/2 * 4kg* (3m) ^2 =
18 kg m^2
moment of inertia of putty = .5kg*(2.5m)^2 = 3.13 kgm^2
Since the putty falls straight down, i assumed the initial angular momentum of the putty was 0. So the initial angular momentum of the system is L_d = 18kgm^2*10 rad/s) = 180 kgm^2/s
Lf = Li, so (I_p + I_d) * angular velocity = 180, angular velocity = 8.52 m/s.
I'm really unsure about this, so I just wanted someone to doublecheck it. Also, I don't really know how to find the average force for part b.
Part (a) is right, except angular velocity isn't m/s.
Hint for part (b): Look up the impulse-momentum theorem
I looked up the impulse-momentum theorem, and I see that force = change in velocity over time. How can I apply this if I don't know the initial velocity of the putty? Can I use angular velocity and say vf - vi = 8.52 rad/s- 0? So force on putty would just be 8.52/.015 seconds?
1. That is not an accurate statement of the theorem. Re-look at it.
https://www.physicsforums.com/library.php?do=view_item&itemid=53
2. No, you cannot simply use the angular velocity. You have to convert it into a linear velocity. How?
You do not know the vertical velocity, so you are right, you cannot say anything about the vertical force that acts on the putty.
I converted the final angular to linear using omega = v/r
8.52 = v/ 2.5
v= 3.41
Since the putty is dropped straight down, can I say the initial velocity in the horizontal was 0 and the final is 3.41 m/s?
Answer to your question: Yes.
Whether 8.52 = 3.41 / 2.5: No.
OK, so now I have vf = 8.52rad/s * 2.5 m = 21.3 m/s
p initial = 0
p final = mvfinal = 21.3 m/s(.5kg) = 10.7 kg m/s
pf - pi = 10.7 kg m/s = J
Force avg = J/ time = 107. kg m/s / .015 s = 713 N
Please let me know if I have done this correctly.
  • · Replies 45 ·
  • · Replies 17 ·
16K
