Conservation of energy in magnets
The discussion centers on the conservation of energy (COE) in the context of permanent magnets. It concludes that creating a magnet does not result in an infinite gain of magnetic potential energy in the universe; rather, the energy required to assemble a magnet from smaller magnets is equal to the decrease in potential energy of the system. The process involves aligning the electron spins in atoms to generate a magnetic field, which has a finite energy density that diminishes with distance. Thus, while magnets can exert forces on metallic objects with minimal energy input, the overall energy in the system remains constant.
  • Understanding of magnetic fields and their properties
  • Knowledge of atomic structure and electron spin
  • Familiarity with energy conservation principles
  • Basic concepts of magnetic potential energy
  • Research the principles of magnetic field energy density
  • Explore the process of magnetization and electron spin alignment
  • Learn about the mathematical integration of energy density over space
  • Investigate the effects of distance on magnetic force and field strength
Physicists, electrical engineers, and students studying electromagnetism who seek to understand the principles of energy conservation in magnetic systems.
User11037
Hi,
With permanent magnets I have been puzzling over how they can obey the conservation of energy.
If I make a permanent magnet then I can use it, expending negligible energy myself, to attract, and thus give kinetic energy to, many other metallic objects.
So, when I create my magnet, do all of the objects in the universe suddenly gain 'magnetic potential energy', in which case I would have to provide an unrealistic amount of energy to produce the magnet?
So how does COE work with permanent magnets?
How do you make a magnet?
the conservation of energy works the same for permanent magnets as it does for everything else. The universe doesn't gain or lose any energy by assembling atoms into a bar magnet for the same reason that the universe doesn't gain or lose any energy when two bar magnets are put together to make a stronger magnet. (atoms can be treated as very small bar magnets of varying strengths and directions)
Though you could say that the potential energy of an object changes in such a case, the potential energy decrease is equal to the energy required to assemble the big magnet from smaller magnets, so the total energy remains constant.
you make a magnet by orienting the spins of the electrons in atoms to point all or mostly in the same direction. the spin of an individual electron creates a small magnetic field just like a loop of current does. When you add all these spins up, you can get a strong magnetic field as in a bar magnet.
You seem to think that the energy in the magnetic field is infinite. It is not. The magnetic field has an energy density which is proportional to the square of the field. Integrating this density over space gives a finite total energy.
yeah. There's two main points in my opinion. 1) the magnetic field takes time to spread out through space. So once you make the magnet, it does not instantly produce a magnetic force on a wire which is very far away. 2) Even when the magnetic field does spread out into space, the strength of this magnetic field decreases with distance, such that the magnetic force on a wire which is further away, is smaller.
How many? The number isn't unlimited, at least not without removing some as well. That takes energy.
  • · Replies 16 ·
  • · Replies 21 ·
  • · Replies 27 ·
