Conservation of energy of sliding block
The discussion revolves around the conservation of energy applied to a 38 kg block sliding up a ramp inclined at 35 degrees with an initial speed of 7 m/s and a coefficient of kinetic friction of 0.5. The user initially struggled with the relationship between potential energy (PE), kinetic energy (KE), and work done by friction (Wf) in the equation PE = KE + Wf. After guidance, the user recognized the need to correctly incorporate the factor of 1/2 in the kinetic energy formula and to express PE in terms of displacement (d) to solve for the distance the block slides before coming to rest, ultimately arriving at a corrected answer.
  • Understanding of potential energy (PE) and kinetic energy (KE) concepts
  • Familiarity with the work-energy principle
  • Knowledge of trigonometric relationships in inclined planes
  • Basic algebra skills for solving equations
  • Review the work-energy principle in physics
  • Learn about the effects of friction on motion in inclined planes
  • Study the derivation and application of the kinetic energy formula, KE = 1/2 mv²
  • Explore problems involving energy conservation in various physical scenarios
Students studying physics, educators teaching energy conservation principles, and anyone interested in solving mechanics problems involving friction and inclined planes.
orionics
Hey folks,
I was trying to work out a problem on conservation of energy and am totally stuck. Was hoping someone could help... the problem was this...
A 38 kg block slides with an initial speed of 7 m/s up a ramp inclined at an angle of 35o with the horizontal. The coefficient of kinetic friction between the block and the ramp is 0.5. Use energy conservation to find the distance the block slides before coming to rest.
I was working with the assumption that at the end of the climb,
PE = KE + Wf
where, PE = potential energy
KE = kinetic energy
Wf = work done by friction = coefficient * Normal force
Reason I get stuck is that there is no d (displacement on slope) or h (height of block at the end of motion). I tried solving one for the other by using h/d = sin theta... but I don't think it's right. :cry:
******EDITED PART STARTS*******
Here's what i had done:
PE = KE - Wf (minus because going up the slope)
mgh = mv2 - (F*d) (F = friction_coeff * m * g * cos theta)
dividing both sides by m*g*d I got...
h/d = (v2/dg) - (F/mg)
but, h/d = sin theta
so,
v2/dg = (F/mg) + sin theta
then I solved for d... and got an answer of 5.1 m. However this was wrong!
******EDITED PART ENDS******
And I've spent an hour on this and am totally frustrated and thus useless ... any and all assistance/clue/guidance will be totally appreciated.
Thanks.
- O
PE = KE + Wf
I would write it like this:
{KE}_i + {PE}_i = {KE}_f + {PE}_f + W_{friction}
KE = kinetic energy
The work done by friction will equal \mu N d, where d is what you are trying to find, the distance the block slides.
That relationship between h and d is exactly correct. Now make use of it in the energy equation and solve for d. (Hint: Express the PE in terms of d.)
made an addendum
Hey Doc Al
I was editing my previous post when you posted your reply. As you'll notice from my edit of the original post... I think I did what you were asking me to do. I got that answer... but found out that it was wrong.
Both {PE}_i and {KE}_f are zero... right? That is why I used the equation I had. Am i wrong?
Thanks again.
Careful: {KE} = 1/2 m v^2. (You are missing a 1/2.)
OMG... I can't believe I did that! :biggrin: .. .and to think I wasted an hour because of a 0.5! I'll try working it out when I get home and see if it's correct.
Thanks a heap!.
