Conservation of Momentum 2D - 2 marbles collide - find final velocities
The problem involves a head-on elastic collision between two marbles of different masses, where the smaller marble (10.0 g) moves to the left and the larger marble (30.0 g) moves to the right. Participants are tasked with finding the final velocities of both marbles after the collision, as well as the changes in momentum and kinetic energy for each marble.
  • Mixed
  • Participants discuss the conservation of momentum and kinetic energy equations relevant to elastic collisions. There are attempts to substitute one equation into another, leading to complications and confusion regarding the calculations. Some participants express difficulty in simplifying their results and question the correctness of their substitutions and calculations.
There is ongoing exploration of the problem with various participants providing insights and corrections to each other's approaches. Some participants have offered suggestions on how to set up the equations and solve for the unknowns, while others are still grappling with the calculations and expressing frustration over their results.
Participants note discrepancies in the total kinetic energy calculations and the need for careful handling of units and terms in the equations. There is mention of a specific homework rule regarding the accuracy of results, as well as references to external resources that may aid in understanding the problem.
durandal995
A 10.0 g marble slides to the left with a velocity of magnitude 0.500 m/s on the frictionless, horizontal surface of an icy, New York sidewalk and has a head-on elastic collision with a larger 30.0 g marble sliding to the right with a velocity of magnitude 0.150 m/s
Find the velocity of each marble (magnitude and direction) after the collision, the change in momentum of each marble, and the change in kinetic energy for each marble.
B=bigger marble
S=smaller marble
(mB)(viB) + (mS)(viS) = (mB)(vfB) + (mS)(vfS)
.5(mB)(viB)^2 + .5(mS)(viS)^2 = .5(mB)(vfB)^2 + .5(mS)(vfS)^2
This problem has been hard for me because I have not figured out how to substitute from one equation to the other. I have solved for the velocity of the Big marble (vfB) but when I substitute it into the kinetic energy equation I end up getting crazy numbers that are hard to simplify.
I solved for vfB and got:
(vfB) = .35(vfS)
When I substitute it though, I get:
.004625 J = .5(.01 kg)*(.05 m/s + 3vfB)^2 + .5(.03 kg)*(vfB)^2
So, I'm getting some pretty crazy numbers that are hard for me to work with. Once I find a final velocity this is going to be easy. Does anyone have a suggestion on how to proceed?
looks good except for the .004625 J. For the total KE I get
.5*.01*.5^2 + .5*.03*.15^2 = .0015875J
I didn't finish it, but from your step above you would just square the binomial in the brackets (results in 3 terms), combine everything into an ax^2 + bx + c = 0 and use the quadratic general solution.
B=bigger marble
S=smaller marble
(vfB) = .35(vfS)
Well, I just did a preliminary run through of your problem and you're right you will have to solve your conservation of momentum problem for one of your final velocities and substitute it into the conservation of energy equation so that you end up with a quadratic equation for the other velocity.
Now, your expression "(vfB) = .35(vfS) isn't correct. You should have another term which will be just a number.
Also, be aware --this is going to be a messy calculation. And, yes the numbers will look "crazy". The quadratic will give you two solutions one of which you will have to discard because it physically doesn't make sense.
Oh I see! I was wondering why my units of measure were getting messed up. I'll give it another run with this instead:
0.017 m/s + 0.333 m/s (vfS) = (vfB)
And thanks for the quadratic equation tip. I can't believe I forgot about that.
I thought you just had a typo in the first equation because I agree with what you substituted in the second for vfB. At least I did before . . . this new value doesn't look right. I get -.01*.5 + .03*.15 = -.0005 for the total momentum.
So after the collision, -.0005 = .01Vs + .03Vb
and Vs = (-.0005 - .03Vb)/.01 = -.05 - 3Vb
That is what you substituted into your 2nd equation in the first post.
Thanks for the save. I'm giving it another go now.
Okay, I'm moving on from here and I must be doing something wrong. I'm getting a number that doesn't work:
.004625 J = .5(.01 kg)*(-.05 m/s - 3vfB)^2 + .5(.03 kg)*(vfB)^2
.004625 J = .0000125 kg (m^2/s^2) + .3 (m/s) + 9(vfB^2) + .015kg(vfB^2)
0 = 9.015(vfB^2) + .3 (m/s)(vfB) - .0046125 (J?)
so those are the A, B and C that I'm plugging into the quadratic formula. I'm getting:
0.0114413 m/s or 0.0447192 Neither seem correct. Where did I go wrong?
I mentioned in my first post that I don't agree with your .004625 for the total energy.
EDIT
Something else wrong here. You should have a middle term with a vfB in it from squaring the binomial: (a+b)^ = a^2 + 2ab + b^2
Leave out the units so it is easier to read.
Also, you can divide both sides by .005 to get numbers easier to write down.
Thanks for the tip. I'm getting 12, .3 and .1025 for A, B and C. Does that look right to you?
I'm getting 12, -.3, -.4869.
Well, I'm about to give up. This question is worth 10% of my grade for this homework but I've been working on it for about 5 hours now. I'm getting vfB = -.189 m/s and vfS = .517 m/s.
vfB should be closer to -.1 m/s and vfS should be closer to +.5 m/s
I am finding those numbers at this site:
faculty.jsd.claremont.edu/jhigdon/phys33/phys33_hw_06_solutions_07.pdf
A marble problem with the same properties but different numbers is on page 6 of this PDF:
Delphi51, thanks so much for all your help. I appreciate you hanging in there with me. I hope that the above link can help anyone that has this same problem. Good luck.
  • · Replies 19 ·
17K
  • · Replies 40 ·
