Conservation of Momentum - Inelastic Collisions
The discussion centers on the conservation of momentum in inelastic collisions, specifically addressing the misconception that velocity remains unchanged before and after the collision. Participants clarify that in a perfectly inelastic collision, the two colliding objects move together with a common final velocity, which differs from their initial velocities. The correct method to determine the final velocity involves using the ratio of the masses of the objects involved. A noted error in an educational animation incorrectly states the final combined speed, highlighting the importance of accurate representations in physics education.
  • Understanding of basic physics concepts, particularly momentum.
  • Familiarity with inelastic collisions and their characteristics.
  • Knowledge of mass-velocity relationships in collision scenarios.
  • Ability to analyze and interpret physics animations and diagrams.
  • Study the principles of conservation of momentum in various types of collisions.
  • Learn about perfectly inelastic collisions and their mathematical representations.
  • Examine the role of mass ratios in determining final velocities post-collision.
  • Review educational resources, such as the Physics Classroom, for accurate physics concepts.
Students of physics, educators teaching momentum concepts, and anyone interested in understanding the dynamics of inelastic collisions.
SkyrimKhajiit
Hello, I recently posted a few conceptual questions regarding conservation of momentum. I'm processing the information more easily now, but I've hit yet another bump in the road. I've learned that in an inelastic collision in which "velocity is the same before and after the collision" the velocity can be determined by dividing the initial velocity by the ratio of mnew:mold. In other words, mass and velocity are inversely proportional:
http://www.physicsclassroom.com/class/momentum/Lesson-2/Using-Equations-as-a-Guide-to-Thinking
(This is the animation): http://www.physicsclassroom.com/mmedia/momentum/fca.cfm
But then, how is velocity the same before and after if it's obviously changing? And when would this situation of being able to find the new velocity by a simple ratio not work?
Thanks, and I know this is going to be a very simple answer pointing out something I missed, but I'm just stumped :D.
Two objects undergoing an inelastic collision end up with the same final velocity. That velocity is different from their initial velocities.
That is not true, independent of the question which velocities you mean.
What are new and old? What exactly do you mean with "dividing [...] velocity by the ratio"? I think I know what you mean, this is a special case - a perfectly inelastic collision where the relative velocity between the collision partners after the collision is zero.
There appears to be a mistake in the video. In the last frame it says the combined speed is 5km/hr, but if you note what it says in the preceding frame you can see that the last frame should say 4km/hr.
  • · Replies 71 ·
  • · Replies 16 ·
