Constancy of speed of light and galiliean transformation
The discussion revolves around the implications of the Galilean transformation in the context of the speed of light and its comparison to the speed of sound. Participants explore the surprising nature of the constancy of light speed across different inertial frames and the incompatibility of the Galilean transformation with light, while questioning why similar issues were not recognized with sound.
  • Some participants assert that the Galilean transformation leads to incorrect predictions about the speed of light, suggesting it should vary with the motion of the source, which contradicts experimental observations.
  • Others highlight that the speed of sound is dependent on the medium, which allows for different measurements based on the observer's motion relative to that medium, unlike light.
  • There is a discussion about whether the speed of light is affected by local spacetime curvature or gravitational fields, with some suggesting that while it is constant in four-dimensional spacetime, its behavior in three-dimensional space may differ under certain conditions.
  • Concerns are raised regarding the measurement of light speed and the potential effects of the Doppler effect on measurements, questioning how instruments can remain unaffected by high speeds.
  • Some participants express confusion about the implications of measuring light speed and how it remains constant regardless of the observer's motion, drawing parallels to sound waves and questioning the consistency of these measurements.
Participants express a range of views on the implications of the Galilean transformation for light and sound, with no consensus reached on the nature of these relationships or the reasons behind the differences in treatment of light and sound.
Participants note that the discussion involves assumptions about the nature of light and sound, the role of the medium in sound propagation, and the effects of motion on measurements, which remain unresolved.
jablonsky27
Hi,
I'm reading up on special relativity and it is pointed out that the galilean transformation dictates that if a light source were moving at velocity v wrt to an observer in another inertial frame of reference, then this observer would calculate the speed of light to be either (c-v) or (c+v) depending upon the source's direction of motion.
Since this is untrue, the galilean transformation is wrong.
My question is why was this a surprising result(inapplicability of galilean transformation to light)?
This is equally true of sound as well isn't it - the speed of sound is independent of the speed of the source.
jablonsky27 said:
Hi,
What was surprising, is that at the same time the relativity principle holds: no motion relative to the ``light medium'' can be detected, the speed of light is measured as c with respect to any inertial reference system. That may seem to be, as Einstein put it, irreconcilable with the postulate that the speed of light in empty space is c, independent of the motion of the source.
- http://www.fourmilab.ch/etexts/einstein/specrel/www/
Note: all observers are in all inertial frames of reference.
the relativity principle states that all physical phenomena have the same form in all inertial reference frames.
applying the galilean transformation to light and any inertial frame results in an incompatibility.
similarly, doesn't applying the galilean transformation to sound also result in the same incompatibility? so i guess my question is, why wasnt it realized wrt to sound itself that there was a problem with galilean transformation and Newtonian mechanics in general?
No, it doesn't, becuase the the speed of sound is relative to the medium through which it is traveling. Thus the speed of sound relative to receiver depends on the velocity of the receiver with respect to the medium. For light, no movement by source or receiver will result in the receiver measuring a difference in the speed of light with respect to himself.
And isn't the speed of light relative to the local space-time curvature, or gravity field?
Ok, it is constant in 4 dimensional spacetime, but does that mean, it is always the same in 3 dimensional space?
You probably have in mind that in a non-inertial frame (for example if the observer is accelerating, or in the realm of general relativity when gravity or cosmological expansion is accounted for) it is possible for the speed of light at some distance away from the observer might not equal the constant c.
But in all cases if you measure the speed of light in vacuum as it passes right next to you, using local clocks and local rulers, you always get the same answer c no matter where you are or how you are moving or accelerating (or how the source moved).
The same does not apply to sound because your speed relative to the medium (e.g. air) makes a difference.
"But in all cases if you measure the speed of light in vacuum as it passes right next to you, using local clocks and local rulers, you always get the same answer c no matter where you are or how you are moving or accelerating (or how the source moved)."
I heard, that they measure speed that they compare the wave amplitudo at the start, and at the end.
So how do you make a difference, that Doppler effect only changed frequency, because you move with c/2 or the light speed relative to you is only c/2?
How can you say, the high speed doesn't effect the measuring instrument?
Sorry but i really don't get it. :(
Light travels through space. How should it know, what speed do i have, so it will hit me with a speed of c, no matter what?
Maybe we could get similar results to sound, if our instruments would use sound waves.
We measure things with EM waves, and light is an EM wave. What effects light, also effects our instruments.
It would be inconsistent to claim that a high speed does not affect our instruments. So, that thing you did get! :smile:
However, we could not get similar results with sound, because our instruments are not at all made of sound waves (they can be thought of made of some kind of electromagnetic waves, see http://en.wikipedia.org/wiki/Matter_wave).
Harald
  • · Replies 34 ·
  • · Replies 22 ·
  • · Replies 53 ·
  • · Replies 36 ·
  • · Replies 33 ·
  • · Replies 57 ·
