Constructing a Dense Measurable Subset in [0,1]
  • Thread starter Thread starter quantumdude
    Measurable
13 replies · 5K views
Construct a measurable set [itex]E\subset [0,1][/itex] with [itex]0<m(E)<1[/itex] such that both [itex]E[/itex] and [itex][0,1]-E[/itex] (that's a set difference) are dense in [itex][0,1][/itex].
None.
Well, the obvious dichotomy here is rationals vs. irrationals, but of course the rationals are countable and hence have measure zero, so that's no good. So now I'm thinking about including [itex]\mathbb{Q}\cap [0,1][/itex] in [itex]E[/itex], plus a selection of irrationals. Unfortunately, I can't think of how to pick the irrationals to go in [itex]E[/itex] without screwing up the denseness of the irrationals.
I have the feeling that this is one of those questions where you either see the trick, or you don't.
I don't. :cry:
I don't understand why you've got "...and [0,1] are dense in [0,1]" is there an extra condition?
That said, in response to:
"Unfortunately, I can't think of how to pick the irrationals to go in [itex]E[/itex]. Reload this page in a moment. without screwing up the denseness of the irrationals."
I have to ask, "Is it ever possible to add points to a dense set, and make that set not dense?"
Sorry, that was a typo. It's fixed now. The condition is that both [itex]E[/itex] and its complement in [itex][0,1][/itex] must be dense.
I wasn't thinking of adding points to the irrationals, I was thinking of taking points away from them and adding them to the rationals, in such a way that I get two sets with nonzero measure. Am I totally off base in thinking that way?
Not necessarily, since this is a rather open-ended question. That said, it's usually easier to operate in terms of intervals since it can be tricky to prove that a particular point set is measureable.
Hint: One way to construct an example is to separate [itex][0,1][/itex] into two intervals.
That doesn't sound right. Both subsets of [itex][0,1][/itex] have to be dense, and the conditions are rigged so as to exclude the trivial examples (such as choosing [itex][0,1)[/itex] and [itex]\{1\}[/itex], for instance). So if I choose two intervals, say [itex][0,a][/itex] and [itex](a,1][/itex] with [itex]a\in (0,1)[/itex], there will be neighborhoods in [itex][0,1][/itex] that do not contain points in one interval or the other (hence, neither will be dense in [itex][0,1][/itex]).
Tom Mattson said:
That doesn't sound right. Both subsets of [itex][0,1][/itex] have to be dense, and the conditions are rigged so as to exclude the trivial examples (such as choosing [itex][0,1)[/itex] and [itex]\{1\}[/itex], for instance). So if I choose two intervals, say [itex][0,a][/itex] and [itex][a,1][/itex] with [itex]a\in (0,1)[/itex], there will be neighborhoods in [itex][0,1][/itex] that do not contain points in one interval or the other (hence, neither will be dense in [itex][0,1][/itex]).
I'm sorry, that wasn't phrased as well as it could have been. I meant that you think of [itex][0,1][/itex] as two intervals and treat each interval differently.
quasar987 said:
now add nate's hint about "splitting [0,1] in two.. as in "[0,½) and (½,1]"
I assume you mean [0,1/2) and [1/2,1], since one subset is to be the complement of the other, right?
Even so, I must be missing something that is obvious to you guys. If I split up the interval like that, then I run into the problem that I described a few posts ago: Neither of those is dense in [0,1], as there are neighborhoods of [0,1] that don't contain any points of one or the other of those intervals.
Let's say that I take each of [itex][0,\frac{1}{2}) [\frac{1}{2},1][/itex] and split them into their rational and irrational components...
Ah, I think I see. The following would be a valid construction for [itex]E[/itex] then.
* Take [itex]\mathbb{Q} \cap [0,1/2)[/itex]
* Take [itex](\mathbb{R}-\mathbb{Q}) \cap [1/2,1][/itex].
* Take the union of the above.
Right, and you should be able to show that all the specified criteria are met.
