Construction Worker Lifting Uniform Beam
2 replies · 6K views · last reply
Fetch
A construction worker attempts to lift a uniform beam off the floor and raise it to a vertical position. The beam is 2.26 m long and weighs 397 N. At a certain instant the worker holds the beam momentarily at rest with one end a distance d = 1.21 m above the floor, as shown in the figure, by exerting a force on the beam.(a) What is the magnitude of ? (b) What is the magnitude of the (net) force of the floor on the beam? (c) What is the minimum value the coefficient of static friction between beam and floor can have in order for the beam not to slip at this instant?
Just equilibrium conditions. Net force and net torque of the system are both zero.
Diagram of a worker lifting a uniform beam from the floor, with the beam tilted and its upper end at height d above the floor; a force P acts along the beam toward the upper end, and d is marked by a vertical dimension line.
So I figured out a)168N and c)0.35 but can't find part b
I tried equilibrium conditions for the vertical forces.
W = 397N
F = 168N
N = normal force
theta = 32.37 degrees
W = Fcos(theta) + N
Solving for normal force I got
397N - 141N = 255N
This answer is wrong. What's confusing me is if I use this value for part C to find the coefficient of static friction it works just fine. The answer isn't zero, and even if it was, that would be wrong because the floor pushes back up on the beam due to molecular compression. I don't get why it isn't 255N? Did I miss something here?
397N - 141N = 255N
That's all correct, but (b) does not ask for the normal force.
Yeah I misconstrued the (net) force part. I figured it out now. I needed the normal force (N) and the x-component of the push (F) to find the net force on the beam. My mistake. Thank you.
