Why is H2SO4 used in the contact process for sulfuric acid production?
  • Thread starter Thread starter gracy
    Contact Process
The contact process for sulfuric acid production utilizes H2SO4 as both a solvent and a reactant, facilitating the conversion of SO2 and O2 into H2SO4. This method allows for the recycling of H2SO4, resulting in a net production greater than the initial input. Impurities in SO2 and O2 can hinder the efficiency of the V2O5 catalyst by adsorbing on its surface, thus obstructing the reaction. The process ultimately yields more H2SO4 than is consumed, demonstrating its efficiency.
  • Understanding of the contact process for sulfuric acid production
  • Knowledge of chemical equilibria and reaction mechanisms
  • Familiarity with the role of catalysts, specifically V2O5
  • Basic concepts of solvent recycling in chemical processes
  • Research the role of V2O5 as a catalyst in the contact process
  • Study the chemical equilibria involved in the formation of oleum from SO3
  • Examine the effects of impurities on catalytic efficiency in chemical reactions
  • Explore advanced methods for optimizing sulfuric acid production
Chemical engineers, industrial chemists, and students studying chemical processes, particularly those focused on sulfuric acid production and catalysis.
gracy
I have a doubt please look at this video
At time 1:54 to 2:00 and from time 3:24 to 3:29 After looking at video at time i have mentioned ,one will find that H2SO4 is itself used in this process so my question is what's the point in making H2SO4 by this method,as the method itself requires H2SO4.What's the net advantage when we are using H2SO4 (along with many other chemical compounds such as SO2,V2O5)and then producing the same?
Chemistry news on Phys.org
If I remember correctly, H2SO4 is used as a solvent. There is a net production of H2SO4 in that process as the acid serving as solvent can be recycled.
OK one more question how impurities in SO2 and o2 reduces the efficiency of V2O5 (used as catalyst) in this process?
They get adsorbed on the catalys thus hindering the reactants to react at the surface.
DrDu said:
They
they means impurities ,right?
DrDu said:
at the surface.
at the surface of catalyst V2O5 ,right?
Yes, yes
OK this explains only about when H2SO4 is used as a solvent but what about when H2SO4 is used as spray?look at this in the video At time 1:54 to 2:00 .how can this be recycled?
There are tons of information readily available on the net. Which ones did you check besides this video?
So i have searched a lot but such type of in depth questions (as my post 7)can only be answered here.That's why i request you to answer my post 7.
Regards.
The sulfuric acid is used to dissolve the SO3 formed which yields oleum. The latter is diluted to form H2SO4 again. So where is the problem?
That's what the problem is,We are using H2SO4 to produce H2SO4 what's the net advantage?
That you get more H2SO4 than you put in.
According to your post 2 that H2SO4 is recycled again,right?
Yes, but obviously not all of it.
And H2SO4 when used as spray consume very less amount of H2SO4 as compared to high yield of end product H2SO4,right?
Acid used in the process is not consumed, it is still present in the final product.
  • · Replies 46 ·
9K
10K
  • · Replies 19 ·
  • · Replies 16 ·
  • · Replies 32 ·
9K
  • · Replies 22 ·
