Continuity and differentiability of f(x,y) = xy²/(x²+y²)
4 replies · 2K views
trap101
Let f: R2-->R be defined by f(x,y) = xy2/(x2+y2 if (x,y) ≠ 0, f(0,0) = 0
a) is f continuous on R2?
b) is f differentiable on R2?
c) Show that all the dirctional derivatives of f at (0.0 exist and compute them
Attempt:
a) I had an idea to show that multivariate functions are continuous, but now I think it's faulty. I did this:
xy2/(x2+y2 ≤ |xy2|/|(x2+y2| < |xy2|
now taking the lim (x,y)-->(0,0) of |xy2| is 0 as such the function is also continuous.
But looking at a similar example from my notes where the only difference in the function was:
xy2/(x2+y6
We had shown that this was not continuous. So now I'm not so sure if the method I used was valid.
b) I'm a little stumped on showing differentiability in this setting, it doesn't seem to involve using the definition directly because of all the possible paths. So what other option may I have?
This is all in terms of discussing the trouble spot. i.e approaching (0,0)
Find the limit when ##x_n = y_n = \frac 1 n ##, and when ##x_n = y^2_n = \frac 1 n ##.
I don't follow. By doing that i get different solutions taking n-->0.
Attempt:
xy2/(x2+y6
So you have :
##f(x,y) = \frac{xy^2}{x^2 + y^2}## if ##(x,y) ≠ (0,0)##
##f(x,y) = 0## if ##(x,y) = (0,0)##
For part a) where you're asked if ##f## is continuous, this should ring bells about the ##ε - δ## definition if you want to show it rigorously. Notice you can already tell that the function is continuous everywhere ( since it is a quotient of polynomials and polynomials are continuous ) except at (0,0). So using the definition with the information we're given :
##\forall ε > 0, \exists δ > 0 \space | \space 0 < |(x,y) - (0,0)| < δ \Rightarrow |\frac{xy^2}{x^2 + y^2} - 0| < ε##
So now you want to massage the expression into a suitable form :
##|f(x,y) - L| = \frac{|x|y^2}{x^2 + y^2}##
Now, using the fact that ##|x| < δ## and ##|y| < δ## you should be able to continue.
n was supposed to be integer, going to infinity. Does that make (x, y) go to zero?
