Continuity of a discrete function
The function F(x) = 1 for x=1, 2 for x=2, and 3 for x=3 is not continuous on the real number line due to its discrete nature, as it jumps between integer values. However, it is considered continuous on its defined domain of integers {1, 2, 3}, where each point has a specific value. The discussion highlights that any function with a discrete domain is continuous within that domain. The term "piecewise continuous" is mentioned but clarified that the function does not fit that definition. Overall, continuity is affirmed within the specified integer range, while discontinuity exists in real space.
peeyush_ali
given a function F(x) = 1 ,x=1
2 ,x=2
3 ,x=3
The above function is a 3 pointed graph. it is continuous . Is it just because every point has a specific value..please someone explain this..??
2 ,x=2
3 ,x=3The above function is a 3 pointed graph. it is continuous . Is it just because every point has a specific value..please someone explain this..??
That function is not continuous, at least not on the reals (it is however, continuous on the integers in the range [1,3]).
Generally, when you talk about a continuous function, you can imagine a graph of the function being drawn with a single curve. In your case, it jumps from integer values, so it would be discontinuous in real space.
I believe the term for the function you have is generally referred to as ``piecewise continuous.''
It might be pointwise equal to a continuous function but, since it is not stated, no conclusion can be drawn.
Any function with a discrete domain is continuous on its domain, since you have defined the function on a discrete domain, it is mathematically correct to say that the function is continuous everywhere in its domain.
Civilized is right. On the domain {1,2,3}, the function is continuous. It isn't even defined on other domains, so you can't make a determination of its continuity on the other domains.
This is true for the simple cases, but not always. For example see the http://en.wikipedia.org/wiki/Cantor_function" . Also, the function defined is not piecewise continuous, but is continuous as mentioned above.
u are right.. civilized
continuity exists in the function just because the function value is mapped in its domain (in this case "specifically...")
  • · Replies 17 ·
