Graduate Continuous Field Image: Hubble Deep Field & Exoplanets
The Hubble deep field image demonstrates that longer exposure times increase the quality of astronomical images by collecting more light, enhancing the signal-to-noise ratio. However, resolution is primarily determined by the optical system's aperture size and pixel dimensions rather than the number of photons collected. Advanced techniques can improve image quality beyond traditional limits, suggesting that resolution can be refined through careful integration over time. Discussions highlight the importance of understanding the nuances of imaging theory, including the implications of pixel size and bandwidth on perceived resolution. Ultimately, while longer exposures enhance image quality, they do not inherently increase resolution.
vinven7
The Hubble deep field image was constructed by collecting photons from a specific region of space over a continuous duration of time; in this case ten days. As the number of collected photons increase, higher the resolution of the image.
If this duration increases, how much more resolution do you get to see? Specifically what if we had a continuous field of view of a certain galaxy - is there some distance for which you could see things in very high definition? Would we be able to see features on exoplanets ? This is of course a function of distance from us, but I am curious to know what kind of information we have about this.
Astronomy news on Phys.org
The resolution does not depend on the number of photons. Instead, the 'quality' of the image increases as you gather more light. A short exposure is very 'grainy' and has a low signal-to-noise ratio compared to a long exposure.
None. :wink:
Resolution is a function of the size of the optical system, specifically the diameter of the aperture, and the size of the pixels on the sensor. Smaller pixels give higher resolution, as long as your optical system can bring the size of the airy disk down to approximately the same size as the pixels or smaller.
Likes russ_watters
That statement could be over-simplified. Basic signalling theory tells us that the limit to resolution depends, not only on the (spatial) bandwidth but on signal to noise ratio. The basic Raleigh criterion is only a rule of thumb. The shape of the dip between two peaks can be refined and refined without limit by integration over a long time. Shannon tells us that the apparent limits, due to pixel size (spatial sampling rate) and aperture can always be exceeded by reducing the bandwidth of the system enough.
This is 'only' an extension of what every good amateur Astrophotographer can get by stacking dozens of images from a light polluted urban environment; a bit more sophisticated than that, though.
I suppose. I wasn't thinking of some of the advanced techniques that can be used to make up for limitations in pixel size and other factors.
That's only a form of sub-sampling which, for non periodic data, can run a coach and horses through what we think of as gospel - ie, The Nyqyuist Criterion. Rules of thumb need to be treated on a case by case basis. :smile:
Ah, well, there you have it then. :wink:
Likes sophiecentaur
UC Berkely, December 16, 2025 https://news.berkeley.edu/2025/12/16/whats-powering-these-mysterious-bright-blue-cosmic-flashes-astronomers-find-a-clue/ AT 2024wpp, a luminous fast blue optical transient, or LFBOT, is the bright blue spot at the upper right edge of its host galaxy, which is 1.1 billion light-years from Earth in (or near) a galaxy far, far away. Such objects are very bright (obiously) and very energetic. The article indicates that AT 2024wpp had a peak luminosity of 2-4 x...
  • · Replies 0 ·
  • · Replies 17 ·
10K
  • · Replies 45 ·
15K
