Contour map of the function showing several level curves
3 replies · 6K views · last reply
cosmos42
ƒ(x,y) = ln(x2+4y2)
I'm not really sure but I solved for y
Handwritten contour map sketch with nested ellipses centred at the origin, y-axis marked 0.5, 0 and -0.5, beside handwritten work solving ln(x^2+4y^2)=0 for y, giving y = ±sqrt(1/4 - x^2/4).
What do you get for y at x=0 from x2+4y2=1? Where is/are that/those on your diagram?
I'm not sure whether you are supposed to plot curves for equal increments in f, as one would on a cartographic map.
"Level curves" are curves on which the expression has a specific value. I would not solve for y. Instead, I would look at the equation [itex]ln(x^2+ 4y^2)= C[/itex] and recognize that, taking the exponential of both sides, [itex]x^2+ 4y^2= e^C[/itex] which is equivalent to [itex]\frac{x^2}{e^C}+ \frac{y^2}{e^C/4}= 1[/itex]. You should immediately see that, for every C, this is an ellipse, centered at the origin, with x intercepts at [itex]\left(-e^{C/2}, 0\right)[/itex] and [itex]\left(e^{C/2}, 0\right)[/itex], y intercepts at [itex]\left(0, -\frac{e^{C/2}}{2}\right)[/itex] and [itex]\left(0, \frac{e^{C/2}}{2}\right)[/itex].
Yes, that was a bit confusing in the OP, but judging from the drawing I would say cosmos42 understood about different values for C.
I was trying to guide cosmos into realising that the curves were centred wrongly.
