Control system - Thermistor, thermocouple, PT100
2 replies · 3K views · last reply
Femme_physics
I'm 95% sure I got it all correct, but I'd appeciate another set of eyes
1) What's a thermistor? What is its principle of action?
2) What's a thermocouple, and what is its principle of action?
3) How does temperature transducer act based on the bimetal principle? Demonstrate your explanation with a drawing.
4) In a certain system given a temperature sensor of the type PT100 that behaves according to the formula
R=R0(1+a(T-T0)
whereas:
a = 0.00385 1/Celsius
R0 = 100 ohms
T0 = The relative temperature = 0 Celsius
A) In a certain temperature R = 215.5 ohms, calculate that temperature.
B) Calculate the temperature you got in clause A in units of Kelvin and Ferheneit.
1) Thermistor - a resistor that changes its resistance depending on temperature due to the crystaline structure of the substance the thermistor is made of.
2) Thermocouple - sensor for measuring temperature. It consists of two dissimilar metals, joined together at one end.
3) The bimetal-principle: A compound strip is formed by riveting or welding two layers of metals, chosen so as to have very different values of linear expansivity. The linear expansivity (old name, expansion coefficient) is the fractional change of length per degree change of temperature and for all metals is positive, meaning that the strip expands as the temperature increases. This bending action can be sensed by a displacement transducer. The conventional type of bimetallic strip element is still to be found in some thermostats, although the strip is very often arranged into a spiral. This allows for much greater sensitivity, since the sensitivity depends on the length of the strip. The amount of deflection can be fairly precisely proportional to temperature change if the temperature range is small.
Diagram of a bimetal strip: a horizontal strip with a lower expansivity metal on top and a higher expansivity metal below, labelled Cold, supported at its left end and resting on a pivot near the right end.
Diagram of a bimetallic strip bent into a curve, fixed at the left end, with a small hatched block labelled Hot to the lower right.
4) http://img201.imageshack.us/img201/2306/frkh.jpg
No interesting transistors or op-amps, so I'll confine myself to just one. :smile:
I think that should be "joined together at the point where temperature is to be measured." Maybe you should mention that a small potential difference develops dependent on the temperature difference between that junction and the other (usually, colder) junction of those same two metal wires.
Good luck with your control exams. http://physicsforums.bernhardtmediall.netdna-cdn.com/images/icons/icon14.gif
Great! You got everything right! :approve:
And with NascO's improvement it's even better!
