Convergence of alternating series
7 replies · 3K views
Incand
Do the following series converge or diverge?
## \sum_{n=2}^\infty \frac{1}{\sqrt{n} +(-1)^nn}## and
##\sum_{n=2}^\infty \frac{1}{1+(-1)^n\sqrt{n}}##.
Leibniz convergence criteria:
If ##\{a_n\}_{k=1}^\infty## is positive, decreasing and ##a_n \to 0##, the alternating series ##\sum_{n=1}^\infty (-1)^{n-1}a_n## is convergent.
I suspect the first series converges and the second diverges but I need to show that.
Starting with the first series it can be rewritten
##\sum_{n=2}^\infty \frac{1}{\sqrt{n}}\frac{(-1)^n}{(-1)^n+\sqrt{n}}##
At this point I had hopes that there exists an ##N## for which ##\forall n \ge N## ##a_n## is decreasing. That is show that
##\frac{1}{\sqrt{n+1}}\frac{1}{-1+\sqrt{n+1}} \le \frac{1}{\sqrt{n}}\frac{1}{1+\sqrt{n}}##. Sadly based on some numerical experiments this doesn't seem to be true so I need another approach.
Another idea was to be able to pair together the coefficients
##\frac{1}{\sqrt{n+1}}\frac{1}{-1+\sqrt{n+1}}+ \frac{1}{\sqrt{n}}\frac{1}{1+\sqrt{n}}## to show that the partial sum ##\lim_{n\to \infty} S_{2n}## exists but I see no useful way to show this either.
You should be able to show the following.
##\displaystyle \frac{1}{\sqrt{n}}\frac{1}{(-1+\sqrt{n})} \ge \frac{1}{\sqrt{n}}\frac{1}{(1+\sqrt{n})}##
then ...
Does ##\displaystyle \lim_{{n\to\infty}} \left(\frac{1}{\sqrt{n}}\frac{1}{(-1+\sqrt{n})}\right) = 0 \ ?##
then ...
Both of these statements are obviously true (the first since ##(-1+\sqrt{n}) < (1+\sqrt{n})##). But I don't see how either one helps me ?
I still have that alternating sign that doesn't allow me to use the comparison test. For example I can't say that ##\sum_{n=2}^\infty \frac{(-1)^n}{\sqrt{n}((-1)^n+\sqrt{n})} \le \sum_{n=2}^\infty \frac{(-1)^n}{\sqrt{n}(-1+\sqrt{n})}##and neither series converges absolutely either.
I'm not sure I should use the Leibniz criteria either, these exercises are taken from a section covering that but I suspect they're meant to show cases where I can't apply that criteria directly or perhaps not at all and have to find other methods.
I think I solved it now. Summing up the ##2n## and ##2n+1## terms seem to work.
##\frac{1}{\sqrt{2n}+2n}+ \frac{1}{\sqrt{2n+1}-2n-1} = \frac{\sqrt{2n+1}+\sqrt{2n}-1}{-4n^2+\dots}##
which is of order ##\frac{1}{n^{3/2}}## and hence converges.
While for the second one doing the same thing
##\frac{1}{1+\sqrt{2n}} + \frac{1}{1-\sqrt{2n+1}} = \frac{\sqrt{2n}-\sqrt{2n+1}+2}{2n}## which is of order ##\frac{1}{\sqrt{n}}## and hence diverges if you do compare it against the harmonic series.
What I intended with my suggestion was to suggest a way for you to use the Leibniz criteria.
You have for the first series: ##\displaystyle \ \sum_{n=2}^\infty \frac{1}{\sqrt{n}}\frac{(-1)^n}{(-1)^n+\sqrt{n}} = \sum_{n=2}^\infty (-1)^n a_n \ ##
Thus ##\displaystyle \ a_n = \frac{1}{\sqrt{n}}\frac{1}{(-1)^n+\sqrt{n}} \ . ## We see that an is positive. for all n ≥ 2, so the series is indeed alternating.
To see that the sequence, [ an ] converges, compare it to the sequence, [ bn ], where
##\displaystyle b_n = \frac{1}{\sqrt{n}}\frac{1}{(-1+\sqrt{n})} \ . ##​
When n is odd, an = bn .
When n is even, an < bn , which is consistent with the first inequality I gave in post #2, and is:
##\displaystyle \frac{1}{\sqrt{n}}\frac{1}{(1+\sqrt{n})}<\frac{1}{\sqrt{n}}\frac{1}{(-1+\sqrt{n})}##​
I think you'll find that the sequence, [bn] converges to 0, therefore, [an] converges to zero
Right that's a good way to show that ##a_n## converges. I never thought about that part since it seemed quite obvious that the sequence converges with the ##\sqrt{n}## factor in the denominator. But this still wouldn't allow us to use the Leibniz criteria right since we don't have a decreasing sequence?
So let's see if I understand this right, your post would be a way to start if Leibniz criteria would be applicable, but in this case it turned out to not be? I included the criteria in the post since most problem in the same section seemed to be using that criteria so I thought it would be of use.
Oh! Of course.
I missed the word 'decreasing'.
DUH !
Then we're on the same page! It didn't help that I thought I should use that criteria for a problem it didn't apply to at the start.
