MHB How can we prove the convergence of recursive defined sequences?
The discussion focuses on proving the convergence of two sequences. For the sequence defined as \( a_n=\left (\frac{n+2000}{n-2000}\right)^n \), it converges to \( e^{4000} \), and the participants emphasize the importance of verifying each step in the limit calculation. The second sequence, defined recursively as \( a_n=\frac{a_{n-1}}{a_{n-1}+2} \) with \( a_1=1 \), is shown to be decreasing and positive, leading to the conclusion of its convergence via the monotone convergence theorem. Participants highlight the need to reference the propositions used in their proofs to avoid errors. Overall, both sequences are confirmed to converge, with discussions on the methods of proof.
mathmari
MHB
Hey! :giggle:
a) Check the convergence of the sequence $a_n=\left (\frac{n+2000}{n-2000}\right)^n$, $n>1$. If it converges calculate the limit.
b) Check the convergence of the recursive defined sequence $a_n=\frac{a_{n-1}}{a_{n-1}+2}$, $n>1$, with $a_1=1$.For a) we have $$a_n=\left (1+\frac{4000}{n-2000}\right) ^{n-2000}\left (1+\frac{4000}{n-2000}\right) ^{2000}\to e^{4000}$$ Having found the limit means that the sequence is also convergent, right? but could we have shown the convergence also in an other way?For b) when we calculate some terms we see the sequence is decreasing and we can prove that using induction. It also holds that $a_n>0$. This means that the sequence converges, right?
:unsure:
Hey mathmari!
That works. (Nod)
We may want to mention which propositions we're using to conclude it though.
It's easy to make mistakes if we take the limits of parts of an expression after all. 🧐
I wouldn't immediately know a different way to do it, other than making sure the steps are correct.
Yep. It follows from the monotone convergence theorem. (Nod)
Klaas van Aarsen said:
That works. (Nod)
I wouldn't immediately know a different way to do it, other than making sure the steps are correct.Yep. It follows from the monotone convergence theorem. (Nod)
Great! Thank you! (Sun)
  • · Replies 17 ·
  • · Replies 17 ·
  • · Replies 44 ·
  • · Replies 21 ·
