Convergence of Series using the Integral Test
  • Thread starter Thread starter llooppii
15 replies · 2K views
llooppii
Determine whether the series (from 1 to infinity) [tex]\Sigma[/tex] 1/(n^(1+1/n)) converges.
I know that since it is positive, continuous, and decreasing, I am able to use the integral test, but I don't know how to anti-differentiate that. I've tried a u-sub, but that didn't lead anywhere. Any help is much appreciated!
I would first try Cauchys condensation test. It says that
[tex]\sum{u_n}~\text{converges if and only if}~\sum{2^nu_{2^n}}~\text{converges}[/tex]
Tell me if you don't know this or if it is inconclusive. I'll figure something else out...
I don't know that test. How does it work?
Well, you take a series with term [tex]u_n[/tex]. You change this into a series with term [tex]2^nu_{2^n][/tex]. If this series converges/diverges, then so does the original series.
Example:
The series [tex]\sum{1/n}[/tex] diverges since the series [tex]\sum{2^n/2^n}[/tex] diverges.
Okay, let's try something else. Do you know the following test?
If {a_n}, {b_n} > 0 and if [tex]\lim_{n\rightarrow +\infty}{\frac{a_n}{b_n}}[/tex] exists and is nonzero, then
[tex]\sum_{n=1}^{+\infty}~\text{converges iff}~ \sum_{n=1}^{+\infty}~\text{converges}[/tex]
If not, can you list all the tests you've seen?
Also, try a ratio test. I think that might work.
An integral test, like you tried, is hard cause u don't know that integral...
You can't apply the integral test directly. Your series is 1/(n*n^(1/n)). Try to think of a function you can replace the n^(1/n) part with that allows you to integrate it and then apply a comparison test. Hint: your given series is really close to being 1/n.
Ah thank you! That really helped. Could i just say that because n^(1+1/n) is always greater than n, that the series must converge because p-series states that p > 1, then the series converges??
No. Because it's not a p-series. I'll also give you the hint that it diverges. Can you find a series that's smaller than the given series that you can show diverges?
No, because p=1+1/n and this is dependent of n. We can only say that 1/n^p converges if p is constant. I'd still try the ration test...
i really can't think of anything that works because i always end up having n^n for i don't know a test for...
The ratio test gives you 1. Did you try it?
What do you think about 1/(n*log(n))? Convergent, divergent?
Does following equation help you?
[tex]\frac{1}{2n}\leq \frac{1}{n^{1+1/n}}[/tex]
i must have done the ratio test wrong then, but it would still fail if it equals 1 though, rite? and I am not too sure about nlogn, but i definitely see how 1/2n works. thank you very much micromass and Dick, i really appreciate your time!
Yeah, I'm sorry about the confusion. The ratio test didn't work ): Glad you've got the answer now (:
That's an even better choice than the one I was thinking of.
