Convergence of the Series (1/n)^p: A Proof for Positive Integer p
  • Thread starter Thread starter ghc
The series \(\sum_{n=2}^{+\infty}(\frac{1}{n})^{2p}\) converges for all positive integers \(p\). The discussion emphasizes the importance of separating values of \(p\) into distinct groups to analyze convergence behavior. Specifically, it highlights that for \(p < 0\) the series diverges, while for \(2p > 1\), the series converges. The harmonic series, which occurs at \(p = 1/2\), is noted as a classic example of divergence.
  • Understanding of series convergence tests
  • Familiarity with the harmonic series
  • Knowledge of mathematical notation and limits
  • Basic concepts of positive integers in mathematics
  • Study the Ratio Test and Root Test for series convergence
  • Explore the properties of the harmonic series and its implications
  • Learn about the p-series test and its criteria for convergence
  • Investigate the implications of separating values in series analysis
Mathematicians, students studying calculus, and anyone interested in series convergence and analysis will benefit from this discussion.
ghc
\sum_{n=2}^{+\infty}(\frac{1}{n})^{2p} where p \in N.
Does this sum converge? How do we calcultate it?
I am not very familiar with maths, so if there is some theorem that can used please tell it to me.
Thank you.
We don't do your homework for you at this site, and this looks very much like homework. (And even if it isn't, we treat questions that look very much like homework as if they were homework.)
Try showing some work. What techniques are there to test whether a series converges? Which ones help with this particular series?
Do you know anything about series? It's a series question. and your series shows different behaviors depending what p you use. for example for p=1/2 the series is the harmonic series which is a famous divergent series. for other values you can use theorems or series tests. for example if p<0 then the series is obviously divergent because it fails the necessary condition to converge. I'll give you a hint.
separate values of p into different groups. like 2p<0, 2p=1, 0<2p<1, 2p>1. That'll be the first step to recognize what the problem asks you to do. I gave you the answer for p<0 & p=1. I let you solve the problem for the other 2 cases. you may not even need to consider the case that 0<2p<1.
About calculating its values, you have to know what p is. moreover, It's usually hard and sometimes extremely difficult to calculate the value of a series.
It is not a homework and I am not a student (and I never was a math student) but I can't prove it. So I will show what I can do :
\frac{(n+1)^{-2p}}{n^{-2p}} = (\frac{n}{n+1})^{2p} \rightarrow 1 if n\rightarrow +\infty
We can't conclude.
\frac{(n+1)^{-2p}}{n^{-2p}} = (\frac{n+1}{n})^{-2p} = (1+\frac{1}{n})^{-2p} = 1-2p\frac{1}{n}+o(\frac{1}{n})
2p&gt;1 the sum converges.
Is this true?
p is a positive integer.
then Yeah the series is convergent for every p in N and your proof seems to be correct to me.
