Convergence testing of the series 1/(2^n-n)
The series \(\sum \frac{1}{2^n - n}\) converges as established through the application of the Ratio Test. The limit \(\lim_{n\rightarrow\infty}\left|\frac{2^n - n}{2^{n+1} - n - 1}\right|\) simplifies to \(\lim_{n\rightarrow\infty}\frac{1 - n2^{-n}}{2 - (n+1)2^{-n}}\), confirming convergence. Additionally, using the comparison test with \(\frac{1}{2^n}\), which is a known convergent series, provides further validation. The discussion emphasizes the importance of factoring and estimating terms to facilitate convergence testing.
  • Understanding of series convergence tests, specifically the Ratio Test.
  • Familiarity with limit calculations in calculus.
  • Knowledge of comparison tests for series.
  • Ability to manipulate algebraic expressions involving exponential functions.
  • Study the application of the Ratio Test in detail, focusing on limit simplification techniques.
  • Explore the Comparison Test and its variations for different series types.
  • Learn about convergence criteria for series involving exponential functions.
  • Investigate other convergence tests such as the Integral Test and their applications.
Mathematics students, educators, and anyone involved in advanced calculus or series analysis who seeks to deepen their understanding of convergence testing methods.
AceK
Determine whether \sum\frac{1}{(2^{n}-n)} from n=1 to infinity converges or diverges.
a_{n} converges if \stackrel{lim}{n\rightarrow\infty}\left|\frac{a_{n+1}}{a_{n}}\right|<1.
I'm really having a tough time knowing where to start on this one. I've tried the integral test, the comparison test, and the ratio test with no luck. Wolfram Alpha says it converges by the ratio test, but I know of no way to simplify \stackrel{lim}{n\rightarrow\infty}\left|\frac{2^{n}-n}{2^{n+1}-n-1}\right|. Is it possible to just say this converges, or is there a mathematical trick to simplifying the ratio? Thanks in advance for the help!
Think about the relative strength of the two terms in the denominator, and try to find a crude estimate to use the comparison test on.
Or you could continue with what you've done using the Ratio test. Factor 2n out of each term in the numerator and denominator.
divide the numerator and denominator with 2^n and the result will be easy to calculate
ystael: I thought long and hard about the comparison test, but the only thing I could think of to use as a comparison is \frac{1}{2^{n}}, which is greater than the original function, and it converges. i also tried variants of replacing 2 with other bases, and I found none that were either convergent and greater than f(x) or divergent and less than f(x).
Mark44: Factoring out 2^{n} results in \lim_{n\rightarrow\infty}\frac{1-n2^{-n}}{2-(n+1)2^{-n}}, correct? I'm not sure I understand how this makes the problem any easier.
I think you mean "less" rather than "greater". But you can modify \sum \frac1{2^n} a little bit to find a series that is greater than the original series, and converges for the same reason that \sum \frac1{2^n} converges.
