Convert Circular motion into figure-8 shaped loop
  • Thread starter Thread starter philns
17 replies · 4K views
philns
TL;DR
For a project I'm starting now, I'd need to convert a circular motion generated from an electric motor into a loop shaped as , through any combination of gears, leverages or mechanical intermediation . So that at a certain level, one fix point on any of those gear would draw an 8 shaped loop. Then defining which elements defines the sizes of the 8 shape. Finally that point should possibly be always on top of any other mechanical element. Maybe there's an easy solution but I can't figure it out.
For a project I'm starting now, I'd need to convert a circular motion generated from an electric motor into a loop shaped as an ∞ , through any combination of gears, leverages or mechanical intermediation . So that at a certain level of the system, one fix point attached onto any of those gears would draw a ∞ shaped loop. Then understanding which elements (size/shape) define the sizes of ∞ movement.
Finally that point should possibly be always on top of any other mechanical element so that during the overall system revolutions it doesn't get overlapped by others.
Maybe there's an easy solution but I can't figure it out on the spot.
An old-school pen plotter could produce Lissajous figures, and one of the first pictures in the Examples section of the Wiki page is a figure of eight. Does that work?
Great hint and suggestion with the Lissajous figures and the formula which stands behind. Very thankful.
Through some more investigation defines that I hardly could achieve it with a single motor but I needed two to generate the two indipendent movement to then combine.
I really needed to translate it into a more mechanical model and so your @Ibix suggestion led me to this video which is very close to what I meant.
Rather simple besides the ratio precision which won't be easy to be achieved just mechanically.
mechanical Lissajous plot
I still wonder if anything similar would be achievable through a single motor and more complex mechanics joints, as that would remove the complexity of achieving very precise two motors synch and precision.
I really wanted to keep all this project electronically simple and purely mechanical without introducing stepping motors and Arduino software controls.
But hey thanks . Very close to the solution .
Philns
Reply
Welcome to PF. :smile:
One idea would be to use 2 co-planar gears meshed so that they counter-rotate in the ratio 1:1. Have some sort of object holder on each that can hand off the object to the other gear at each full rotation when the holders meet each other at the gear mesh point. I can envision several ways to make the holders so that they can hand the object back and forth each time they meet.
BTW, is this project for schoolwork? Or maybe a personal art project?
philns said:
Through some more investigation defines that I hardly could achieve it with a single motor but I needed two to generate the two independent movement to then combine.
You need a ratio of exactly two, so one motor can turn one gear that generates x, while a second gear, meshed with the first, generates the y position. Chains, or cheap stepped belts, are another way of generating the exact ratio of two.
Thanks Berkeman
I'd think though handing off an object between 2 moving gears is a rather ingenious solution but full of complexity in avoiding getting it stuck. I'm so curious about what you envisioned there.
Getting back to your question I'd define my project as personal art. It gets close to that definition I suppose.
And I'm so happy I've found this place, as I'm learning so much from this widespread knowledge.
Reply
Thanks Baluncore
Indeed, to get the 8 shaped move I'll need the 1:2 ratio. And that solution of one motor two gears with proper ratio and a stepped belt would achieve simplicity, mechanical solution and precision all together.
I think I'll evolve onto this path. Let me see what comes out from a simple prototype.
Two methods I came up with from tracing out figure 8s. The first produces a somewhat uneven one as is, but you can slightly adjust the shape by fiddling with the lengths of the Arms at bit, and might get something better.
The second method produces a more symmetrical path. It's overall shape can be varied by where you put the pivot points for the rods on the gears.
Reply
  • Love
Nice. The second one is essentially the Lissajous figure approach I suggested, I think. Though you've obviously thought it tgrough in more detail. :smile:
Are those diagrams done in Blender?
Yes, done with Blender.
Reply
I think I can see how to do all of it with simple animation and "copy x/y coordinate" constraints except for the red path. Is that manually calculated, or did you get Blender to generate it somehow?
(Sorry for the digression, OP. I'll stop hijacking after this post.)
Reply
Well, I'm interested in that too, so thanks for the digression :wink:
Reply
The top one was done using armatures, which act like a chain of bones, in this case, 2 bones. The base of the chain is parented to the smaller gear so it follows it as it rotates. the other end of the chain is parented to an "empty" (essentially an invisible placeholder for an object). and that empty is parented to the larger gear. This last bit involves Inverse kinematics, which causes the chain of bones to react to the motion of the empty without having to animate each bone separately.
With the second, each arm is parented to its respective gear and given constraints to limit their rotation so they maintain a fixed orientation. And while I could have used drivers to mathematically control how the peg in the slots moved, I opted for a more "brute force" approach where I simply manually positioned it every 3 frames and added a keyframe. The red lines used a similar brute force approach, where I added a "path curve" and manually adjusted it to follow the path of the peg, then converted it to a tube to give it some thickness.
Reply
Thanks, @Janus. So it's not fully using Blender as a physics engine, but it's automated enough that the motion of the pen is computed. So even if you've done some manual drawing, it's based off (and consistent with) the automated bits.
I think there'd be a practical problem with the orthogonal arrangement. When the horizontal bars are at the 3 o'clock/9o'clock position, they exert no driving force on the wheels at the right. The bars would not remain horizontal. This could be fixed by adding gear trains to drive the right hand wheels from the gears independently of the bars.
Since the original animation was just to show the basic idea, I didn't include those types of restraints as it would be simple to do something like this instead to keep the bars oriented.
Reply
Of course, now you inspired me to do a more physics engine driven example. In this animation, the boxes actually constrain the cylinder using rigid body physic, then the path is traced out using geometry nodes. I didn't do a figure eight, but just basically gave the boxes some random motions, and let everything else naturally follow.
As a consequence, there is a little bit of "wiggle" in the line since there is some slop between cylinder and boxes.
Reply
A four bar linkage can generate a figure 8 path. There are four bar simulations online to save you the time to create your own. This one took about five minutes to find and get it to generate a sloppy figure 8. Some additional tinkering can get a much better figure 8. I leave that as an exercise for anybody interested.
Reply
