Convert repeating decimal to improper fraction
  • Thread starter Thread starter oddjobmj
    Convert Fraction
10 replies · 8K views
oddjobmj
Convert 23.588 (the 88 is repeating) to an improper fraction.
I don't have any.
I'm not sure of the best way to go about this so I've taken a method that I've seen on some problems that were more simple as they didn't have the 23.5 in front of the repeating decimal.
I see that this can be broken down into:
23 + .5 + 8/10 + 8/10(1/10) + 8/10(1/10)^2...etc.
Although, I'm really not sure how to collapse the infinite progression of 8/10(1/10)^n into an actual number.
I've tried plugging 8/10 in for 'a' and 1/10 in for 'r' in the infinite progression equation:
a/(1-r)
This results in 8/9 then adding 1/2 to that we get 25/18 and then adding 23 to that I get 439/18
However, this result is not correct.
Any help/suggestions are welcome. Thank you for your time!
you have:
needs to be:
23 + .5 + 8/100 + 8/100(1/10) + 8/100(1/10)^2...etc.
This corresponds to a geometric series with a=8/100 and r=1/10
so the fraction would be the sum of the series (using a/(1-r)) plus 23.5
23.5+ (8/100)/(1-1/10)=23.5+8/90=47/2+8/90=2123/90
Ohh, of course I'd make a silly mistake like that...
Thanks!
There's an easier way, as a matter of fact.
Let a=23.5888... (I'm using ellipses to represent repeating decimals.)
Then 10a=235.888...
and 100a=2358.888...
Subtraction will get rid of our repeating decimal.
Therefore, 90a=2123
a=2123/90.
23.5888...=2123/90
I got this from Numbers, Rational and Irration by Ivan Niven, which I recommend. It doesn't use any advanced mathematics.
oddjobmj said:
How did you jump from 100a=2358.888 to 90a=2123?
100a-10a
good call on the easier way.
a=8/10
10*a=8
You'd obviously get 90a on the left but how do I know to use 10 and multiply by 100 and how does 2358.888888888888 - 8 = 2123?
a=23.5888...
not 8/10.
I have no idea where you got that from.
Anyway, if
a = 23.588...
10a = 235.88...
100a = 2358.88...
Notice now that if we do 100a-10a, the 8's repeating will cancel each other out.
2358.888...
-235.888...
=2123.00...
=2123
But 100a-10a=90a, so if 90a=2123 then a=2123/90.
Try it in the calculator :smile:
If you have a single digit repeating infinitely it can be reduced to finding the representation of .111...
You should be able to find that with a bit of playing.
Awesome :D Thank you jtyler, brainy, mentallic, and integral!
These techniques will all help me significantly on my test/exam coming up.
