Converting between base 7 to 3
  • Thread starter tnutty
    Base
9 replies · 5K views · last reply
tnutty
convert (352416)_7 to (...)_3
the _7 means base 7 and similarly, _3 means base 3.
Idea : convert base 7 to base 10 then base 10 to base 3.
I know I can use expansion, 3 * 7^6 + 5 * 7^6 ... to convert it to base 10.
but in my exam, we are not allowed to use calculators, and I really not want to spend time
on figuring out the power of X. So do you know a faster way to convert this to base 10?
From then on I could convert it to base 3.
I can't think of any way other than brute force, which is what you're doing. BTW, it would be 3*75 + 5*74 + ... + 1*71 + 6
You could make a couple of shortcuts, though. 74 = 492 = (50 - 1)2 = 502 - 2*50 + 1 = 2500 - 100 + 1 = 2401.
Also when say the number turned out to be something like 443267. Then to change this
number of base 10 to base 3, I could divide by 3 and get the remainder. But is there another way that you can think of.
And could I have just divided the base 7 number by 3 to turn it into base 3?
Once you have converted to a base-10 number, subtract the highest power of 3 that is <= your number. It's probably easier to just show an example than to explain the process.
Suppose you want to convert 4325 to its base-4 equivalent. 4325 = 11710.
The powers of 4 are 1, 4, 16, 64, 256, and so on.
117 = 64 + 53, so my base-4 representation is going to be 1xxx.
53 = 3*16 + 5, so now I have 13xx
5 = 4 + 1, so I have 131x.
My final remainder is 1, so the number we want is 13114.
It might be possible to convert directly from base 7 to base 3, but that requires you to know arithmetic in both bases; e.g. to be able to know that 6*4 = 21 in base 7, that sort of thing.
Yes, it's pretty simple in this case but be sure to express everything in base 7:
[tex](352416)_7=3 \times (115352)_7+0[/tex]
[tex](115352)_7=3 \times (26340)_7 +2[/tex]
[tex](26340)_7=3 \times (6560)_7 +0[/tex]
[tex](6560)_7=3 \times (2164)_7 +2[/tex]
[tex](2164)_7=3 \times (521)_7 +1[/tex]
[tex](521)_7=3 \times (152)_7 +2[/tex]
[tex](152)_7=3 \times (40)_7 +2[/tex]
[tex](40)_7=3 \times (12)_7 +1[/tex]
[tex](12)_7=3 \times (3)_7 +0[/tex]
[tex](3)_7=3 \times (1)_7 +0[/tex]
[tex]\Rightarrow (352416)_7=(10012212020)_3[/tex]
I think that [tex]6\times 4=33[/tex] in that base.
Yea, that what I do with power of 2's.
Thanks everyone.
