Converting relativistic acceleration from coordinate time to proper time
13 replies · 2K views · last reply
timetraveller123
it is known that
##a_0
##is the proper acceleration
a= \frac{a_0}{\gamma^3}
hence integrating it gets
v = \frac{a_0t}{\sqrt{1 + (\frac{a_0 t}{c})^2}}
but this is in terms of t how to make it in terms of t'
i don't really get your question it is too complicated for me i only know the basics could please simplify it for me thanks
How does ##dt'## relate to ##dt##? Hint: Time dilation.
ooh that
are you asking for this
dt = \gamma(dt' + \frac{xu}{c^2})
or
dt = \frac{dt'}{\gamma}
vishnu 73 said:
the second one
So how can you use that to find ##t## as a function of ##t'##?
the t in time dilation is the time of event measured by each observer but in my case t is the length of the time that has passes from the start
oh okay so considering infinitesimal times is it
dt' = \frac{dt}{\sqrt{1 - \frac{v}{c}^2}}\\
substituting for v(t)
dt' = \frac{\sqrt{c^2 + (a_0 t)^2}}{c} dt
is it that ?
You have put ##dt'## on both sides in your post ...
but still this is the answer to the second part of the problem how to get answer to first without doing second part
I did not notice before, but you have mixed up the relation between ##dt'## and ##dt##. The proper time elapsed should be smaller than the coordinate time and so the ##\gamma## has to go on the other side, i.e., ##dt' = dt/\gamma##.
The way you are doing it you will get the answer to (b) first. Why is that a problem? It is possible to do it in a different way, but you should not let getting the result to a later part as a byproduct when solving an earlier part confuse you and think that it is impossible to do it that way just because you get a result that is asked for later on the way.
