Convex lens questionCant find the equation i need. Please help
A convex lens with a focal length of 0.8m is used to focus a real image of the moon, which subtends an angle of 0.5 degrees. The user is seeking help to find the appropriate equation to calculate the size of the moon's image on a screen, specifically using the lens formula 1/f = 1/u + 1/v. It is clarified that since the moon is far away, the object distance (u) can be considered infinite, simplifying the calculations. The derived equation leads to an image distance (v) of 4m, but there is uncertainty regarding how to incorporate the angle subtended by the moon into the final calculation. The discussion emphasizes the need for clarity on the relationship between the angle and the image size.
sidge2222
A convex lens of focal point 0.8m focuses a real image of the moon onto a screen. If the moon subtends an angle of 0.5 degrees to an observer on earth, calculate the size of the moons image on the screen?
Thats the question guys, I am really struggling to find the appropriate equation as we havnt been given any by out lecturer as he's been off ill. It needs be in after half term and we don't have any equations, i would greatly appreciate any help.
Im new to this forum so just wanted to say hi to everyone as well :)
Si
Because i have the focal point of 0.8, I am assuming that i should use the normal lens equation of 1/f = 1/u + 1/v which would be rearranged to 1/v = 1/f - 1/u because v = lens to image, so because I am after the size of the moons image on the screen this is what I am thinking is the correct equation. Am i right in thinking this guys??
So if I am after v, i need to obtain u in order to complete the equation - so am i right in thinking i need a sort of equation in order to convert the 0.5 degrees into a relevant figure??
Looking forward to your replies :)
Si
bump - sorry
If you draw a picture you can find out how is the angle of view related to the ratio of the object height to the object distance and that of the image height to the image distance. As for the object distance, the Moon is so far away that the object distance can be considered infinity. Where will be the image than?
ehild
so if u is infinitie that means its 1 right?
then my complete equation will be:
1/v = 1/f - 1/u
1/v = 1/0.8 - 1/1
1/v = 1/0.25
v = 4m
This seem right guys?? I am unsure as I am missing the moon subtending an angle of 0.5 degrees, which too be honest I am quite unsure about
thanks for the reply so far and for everyone that's had a read :)
Si
1 is not infinite. At the limit u→∞ 1/u→0.
ehild
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
