Convolution theorem for Laplace Transform proof
The discussion centers on understanding a specific step in the proof of the convolution theorem for the Laplace transform, particularly the reversal of integration limits. A participant seeks clarification on how the integration domain changes when switching the order of integration in the iterated integral. The explanation highlights that the integration limits are determined by the wedge-shaped region in the (t, τ) plane, as depicted in Figure 12.28. By fixing one variable, the allowable values for the other variable within the defined domain can be established. The conversation emphasizes the importance of visualizing the integration domain to grasp the limits effectively.
marksman95
Hi all.
Sorry about creating this new threat despite existing some others on the same topic.
I have a problem in understanding a very specific step in the mentioned proof.
Let me take the proof given in this link as our guide.
My problem is just at the ending. When it says:
"The region of integration for this last iterated integral is the wedge-shaped region in the (t, τ) plane shown in Figure 12.28. We reverse the order of integration in the integral to get:"
$$F(s)G(s) = \int_0^\infty \left[ \int_0^t f(t)·g(\tau-t)·e^{-st}\; \mathrm{d}\tau\right]\; \mathrm{d}t$$
I don't understand how this reversion gives these limits of integration. How do we get from
$$F(s)G(s) = \int_0^\infty \left[ \int_\tau^\infty f(t)·g(\tau-t)·e^{-st}\; \mathrm{d}t\right]\; \mathrm{d}\tau$$
to there?
Thanks.
It is simply two different ways of defining the integration domain, which is shown in figure 12.28.
Since both parameters can be 0 to ##\infty##, the outer integral necessarily needs to be from 0 to ##\infty##. The inner integral must be such that you integrate over the shaded domain and nothing else. If you have fixed ##t## what values can ##\tau## take within this domain? If you have fixed ##\tau##, what values can ##t## take in this domain?
Thanks Orodruin!
But now I think my problem is with this integration domain which is shown in the figure...
Could you (or someone else) explain how this integration domain is found and understood?
Thanks again!
The integration domain looks the way it does because of how the integral was constructed in the first place. This comes about when they change variables from ##\sigma## to ##t## in the inner integral.
That's right, the visual picture on the 2nd page really helps to see this.
The original inside integral (which you have posted 2nd marskman) is integrating first from left to right or, from t= τ (tau) to ∞, then the outside covers the bounds (τ=0 to τ=∞) But then by reversing the order you'll go from τ=0 to τ=t as the new inside function then cover the remaining bounds, again, from t=0 to t=∞.
Manipulating the order of integration made many problems easier in multivariable calc.
I'm scared.....
  • · Replies 17 ·
