Admin
- 69,823
- 25,756
At least the last part of your post is incorrect, I believe. Do you have links to the other assertions in your post?bob012345 said:I've read about devices that direct IR radiation from objects to the night sky which is effectively a radiator to space though not as effective as actually being in space. You can make ice even when the ambient air is in the 50's F. Cleverly designed systems may be able to convert the IR radiation of the Earth or of solar warmed objects such as rooftops to useful energy by passive radiation to space as the cold sink. The Earth typically radiates over 300 W/m^2 at night. Of course doing all that may not be worth the cost and complexity.
It looks like you are confusing the reflective albedo of the Earth during the daytime (when insolation is around 1kW/m^2) and the much lower radiation during the night...
from -- http://eesc.columbia.edu/courses/ees/climate/lectures/radiation/
The Earth's albedo.
The Earth's surface reflects (that is, returns the radiation back to space in more or less the same spectrum) part of the solar energy. This is what makes the part of the Earth lit by the sun visible from space (Figure 8) in the same way that the moon and the other members of the solar system are visible to us, despite their lack of an inner source of visible radiation. The most obvious aspect of Figure 8 is the brightness of the Earth's cloud cover. A significant part of the Earth's reflectivity can be attributed to clouds (this is but one reason why they are so important in the Earth's climate). In climate texts the reflectivity of a planet is referred to as the albedo (that is, albedo = reflectivity) and is expressed as a fraction. The albedo of Earth depends on the geographical location, surface properties, and the weather (can you tell from Figure 7 which has higher albedo, the land or the ocean?). On the average however, the Earth's albedo is about 0.3. This fraction of incoming radiation is reflected back into space. The other 0.7 part of the incoming solar radiation is absorbed by our planet.
