Correlation coefficient between continuous functions
3 replies · 6K views · last reply
natski
Hi all,
The correlation coefficients (Pearson's) is usually defined in terms of discrete sampling of a function. However, I have seen that the mean and standard deviation, for example, are also typically written in terms of discrete variables BUT may also be expressed in terms of a continuous probability distribution. e.g. the mean may be written as \mu_x = \int x p(x) dx.
So my question is, does there exist a similar formalism for the correlation coefficient between two continuous probability distributions? Any help would be greatly appreciated on this issue for which many Google searches came up empty handed. :-)
Natski
I found a reference: Cuadras 2002, On the Covariance between Functions, which has a cited solution form 1940 known as Hoeffding's lemma. This lemma is based on the cumulative distribution functions.
Does anyone know how to go from two independent P(x) and P(y) to C(x,y) where P's are the prob density functions and C is the multivariate cumulative distribution function?
Natski
Actually correction to my last post, the two variables are not independent. Here is the problem restated for my exact case.
P(x) is a uniform distribution and = (1/Pi) for all x between 0 and Pi
Now let u = Sin[x] and v = Cos[x]
What is the joint probability distribution G(x,y)? I know how to do univariate and bivariate transformations by using the Jacobian but to go from univariate to a bivariate seems to require a 2 x 1 Jacobian for which no determinant can be computed. This is where I get stuck.
The joint distribution isn't needed because you already have U and V as functions of X, so E(UV) etc are 1d integrals.
