Coservation of energy and impulse
  • Thread starter Thread starter gongshow29
    Energy Impulse
The problem involves a stream of elastic glass beads falling from a tube and bouncing back, with the goal of determining the mass needed on a balance pan to maintain equilibrium. The subject area includes concepts of conservation of energy and momentum in the context of mechanics.
  • Mixed
  • Participants discuss calculating the velocity of the beads as they hit the pan, considering both energy conservation and momentum. There is exploration of how to incorporate the rate of beads falling into the calculations.
Participants have provided guidance on using conservation of energy to find velocity and then applying that in momentum calculations. There is ongoing clarification regarding the correct units and calculations, with some participants questioning the setup and suggesting corrections.
There is confusion regarding unit conversions and the interpretation of the calculations, particularly in how to express mass in grams versus kilograms. The discussion reflects a need for careful attention to detail in the calculations and assumptions made.
gongshow29
A stream of elastic glass beads, each with a mass of 0.46 g, comes out of a horizontal tube at a rate of 108 per second. The beads fall a distance of 0.54 m to a balance pan and bounce back to their original height. How much mass must be placed in the other pan of the balance to keep the pointer at zero?
1/2mv^2
What I attempted was solving for the velocity of the ball as it hits the pan, then I multiplied by the mass, but I am not sure of how to account the rate.
Rate is necessary as force is momentum change per unit time. You need not think in terms of energy rather think of force acting on the pan as momenta lost by the beads PER UNIT TIME.
The force on the pan will be 2*n*d/dt(m*v)
n being the number of beads hitting the pan per unit time.
v being the VERTICAL velocity of a bead as it hits the pan.
n is the rate here so don't you think d/dt(mv) is misleading?
Yes it is. It should be 2*n*m*v?
Yes.
Would I just use the conservation of energy to solve for the velocity then? Or momentum?
Use conservation of energy to find the velocity. Then use the velocity in the momentum calculation.
so I would use the following setup mgh=1/2mv^2 correct?
I calculated my velocity with that setup
(0.46)(9.81)(0.54)=(1/2)(0.46)v^2
ended up with 3.254...
plugged that into the formula suggested which was 2(n)(m)(v):
2(108)(0.46)(3.254)=323g, but that is giving me the incorrect answer?
Where am I going wrong in my calculations?
0.46g is in g; should be in kg.
Ok, I switched out 0.46g into 0.00046kg, did the same calculation ended up with .010227kg, and my answer wants it in grams, so I multiplied it by 1000, for 10.227g, and its still incorrect. I am really confused now.
Ok, first of all, you should get a value of 0.323, but that is in Newtons.
Find the mass that is needed to balance that force.
Ok that makes sense, appreciate everyone's help.
  • · Replies 24 ·
