Is Carlos Barcelo's Research Redefining Cosmology and Gravity?
  • Thread starter Thread starter Chronos
    Cosmology Gravity
Carlos Barcelo's research proposes a modification to Einstein's cosmological equations, suggesting that the cosmological constant should not be constant but rather dependent on the universe's matter content. This new model aims to align more closely with Einstein's static solution and addresses issues like the horizon problem inherent in standard cosmology. The model predicts an oscillating universe and attempts to reconcile observations of supernovae with its theoretical framework, although it faces challenges regarding its compatibility with current data. Barcelo's work builds on the concept of emergent gravity, indicating that gravity may not be fundamental but rather a low-energy consequence of more complex theories. Future research will explore the model's alignment with observational data, particularly in relation to Big Bang nucleosynthesis and cosmic microwave background radiation.
Chronos
I was intrigued by this paper and the approach:
http://arxiv.org/abs/gr-qc/0611090
Cosmology as a search for overall equilibrium
Authors: Carlos Barcelo
Comments: 9 pages, 1 figure
"In this letter we will revise the steps followed by A. Einstein when he first wrote on cosmology from the point of view of the general theory of relativity. We will argue that his insightful line of thought leading to the introduction of the cosmological constant in the equations of motion has only one weakness: The constancy of the cosmological term, or what is the same, its independence of the matter content of the universe. Eliminating this feature, I will propose what I see as a simple and reasonable modification of the cosmological equations of motion. The solutions of the new cosmological equations give place to a cosmological model that tries to approach the Einstein static solution. This model shows very appealing features in terms of fitting current observations."
This builds upon earlier works in collaboration with Matt Visser on the concept of Analogue Gravity - an alternative to string and LQG approaches to quantum gravity. It is an interesting idea that, by all appearances, is more touchy feely [testable] than these approaches. It has some warts, mainly the inability to produce the expected quantum backreactions, but not yet mortally wounded so far as I can see.
The idea is substantially based on this also fascinating paper from 2001:
Einstein Gravity as an emergent phenomenon?
Authors: Carlos Barcelo, Matt Visser, Stefano Liberati
Comments: 8 pages, Essay awarded an honorable mention in the year 2001 Gravity Research Foundation essay competition
Journal-ref: Int.J.Mod.Phys. D10 (2001) 799-806
"In this essay we marshal evidence suggesting that Einstein gravity may be an emergent phenomenon, one that is not ``fundamental'' but rather is an almost automatic low-energy long-distance consequence of a wide class of theories. Specifically, the emergence of a curved spacetime ``effective Lorentzian geometry'' is a common generic result of linearizing a classical scalar field theory around some non-trivial background. This explains why so many different ``analog models'' of general relativity have recently been developed based on condensed matter physics; there is something more fundamental going on. Upon quantizing the linearized fluctuations around this background geometry, the one-loop effective action is guaranteed to contain a term proportional to the Einstein--Hilbert action of general relativity, suggesting that while classical physics is responsible for generating an ``effective geometry'', quantum physics can be argued to induce an ``effective dynamics''. This physical picture suggests that Einstein gravity is an emergent low-energy long-distance phenomenon that is insensitive to the details of the high-energy short-distance physics."
Some tantalizing related material has arisen in condensed matter physics along these lines. Perhaps there is an underlying 'apples to oranges' problem with existing approaches to quantum qravity.
Space news on Phys.org
Do these alternative approaches that asyptotically approach GR in the present low density limit also predict concordant BBN and CMB observables from the high density epoch?
Garth
I don't think those questions are relevant to the model, Garth. It does not forbid or require BBN, or CMB anisotropy, so far as I perceive.
Thank you Chronos.
The model is an oscillating universe one.
From the OP paper:
The author seems to be saying that the SN Ia observations already contradict the model:
Taking the currently accepted values of \Omega_{\Lambda} ∼ 0.7 and \Omega_M ∼ 0.3 [21], our model predicts that the acceleration that we observe should be decreasing with time at present and so be bigger in the past. The fitting of the supernova data at high redshifts seems to provide an indication of the contrary [22]. The acceleration appears as nonexistent in the past, giving support to models of dark energy as the Chaplygin gas (see for example [23]). However, by making global comparisons between different cosmological models, other authors argue that it is still impossible to discern, for example, between a cosmological constant and varying dark energy [24].
However, the recent HST observations of SN Ia at high z may reverse this conclusion.
In the BBN high energy regime:
The “close to Big Bang” origin of the universe in our model allows for incorporating most of the predictive power of this paradigm. However one has to bear in mind that any realistic calculation within our model will have to take into account two new factors:
i) Since its entropic birth, the universe could have passed through a few entire cycles before entering in its current expansive phase;
ii) In each new cycle, the maximum value of the acceleration attained, proportional to (itex screwed up here), would be smaller.
For example, the diminishing of the duration of a single phase of nucleosynthesis, owing to the background acceleration predicted for that period, could be compensated with the plausible existence of a few cycles reaching large enough temperatures for nuclear reactions to take place.
Cosmology as a search for overall equilibrium 8
• In this model the time elapsed since the entropic birth of the universe (Big Banglike) would be much larger than in standard cosmological models. We have much more time to produce structures in the universe, something that has always been problematic in standard cosmology.
• This model does not have the so-called horizon problem of standard cosmology asthere is not a “beginning of time” event. Therefore, radiation could have enough time to thermalize in very large scales. If the current cycle would have started at a temperature smaller than Trecombination, then, the size of the inhomogeneities found in the cosmic microwave radiation would not directly constraint the size of the inhomogeneities in the barionic matter sector in recent times.
• Within this positive curvature model, the found values OmegaLambda +OmegaM ~ 1 and H0 ∼ 14.000 Gyears would be just telling us that the universe is very large, R0 ≥ 100 Gpc with R0 its current physical radius, so locally it would be almost flat.
Further checking of the compatibility of this cosmological model with actual observations will be the subject of future work.
So the model does affect BBN, but the author sees ways of compensating for this.
Garth
Contradicting type 1a observations seems a recipe for disaster. I thought type 1a's are our best standard candles.
The best maybe, but that does not necessarily mean they are good! :wink:
There could be cosmological or systematic effects that result in their apparent magnitudes being fainter than expected.
The paper, as I read it, is simply claiming we cannot be sure about such a falsification.
Garth
What about Cepheid Variables? Does the author criticize their use as standard candles too? (I haven't read the paper)
They cannot be seen (yet) at such cosmological distances.
Garth
"In this letter we will revise the steps followed by A. Einstein when he first wrote on cosmology from the point of view of the general theory of relativity. We will argue that his insightful line of thought leading to the introduction of the cosmological constant in the equations of motion has only one weakness: The constancy of the cosmological term, or what is the same, its independence of the matter content of the universe..."
As I understand it, with the expansion of the universe comes an horizon, and horizons produce a bath of thermal particles. I take it that these particles can be permanent and can have mass. So it would seem that the matter/photon content of the universe is not constant as previously suspected. I wonder if this has been taken into account in the cosmological models.
The universe has always had a horizon. Particles always emerged inside that horizon. Photons had already established the boundary conditions. But spacetime had the jump. Photons [and baryons] were trapped inside the surface of last scattering giving spacetime a huge, inflationary headstart.
I have to wonder how there could be an horizon before there were photons. If photons (and baryons) were formed because of the contraction of the horizon, how was there ever a horizon to begin with before photons? How can you establish the speed of photons without photons?
As R.M. Wald says, perhaps particles are not feasible in tightly curved and changing spacetimes. So I suspect that the reason Inflation was so fast was because it was so tightly curled that no particles could exist to prevent its expansion through gravity? In other words, all there was before particle was vacuum energy. All the particles came from this vacuum energy. But before this vacuum energy decayed into particle it caused a negative pressure of expansion on the universe causing it to inflate.
It is not necessary to have any particle to define a horizon. A horizon is determined by the behaviour of geodesics is space-time.
The question whether there existed particles or fields seams not relevant to me here. What is relevant is the energy density that determines the behaviour of the scale factor according to the Friedmann equations. During inflation the energy density of the inflaton with an equation of state p = - \rho was the dominant one. This lead to an accelerated expansion of space.
Moreover, the curvature of space-time seams also to be irrelevant. Consider a spatially flat universe (the universe became nearly flat soon after the start of inflation), with k = 0. The evolution of the scale factor during inflation is:
a = e^{Ht}
with H the constant Hubble parameter during inflation. The most simple quantity that tells you something about curvature of space-time is the Ricci scalar:
R = \frac{6}{a^2}(a \ddot a + \dot a^2 + k)
Inserting for the scale factor:
R = 6 H^2
As you can see, the curvature of space-time is the same before than after inflation (H remains constant in a de-Sitter space-time).
Excellent post hellfire. I merely wish to add that if gravity was emergent in the early universe, inflation had no brakes until gravity emerged from the chaos. I'm not comfortable with an infinite rate of expansion [a quantum fluctuation thing], but, I can see how it might easily have run wild in the first few Planck ticks of time. I feel free to take poetic license here because causality has little meaning before matter freezes out of the primordial soup.
I completely agree Chronos. Until space had grown sufficiently to thin out its Energy density, gravity was much to weak to influence any structural influence on the emerging universe.
You seem to be assuming that other fields coexisted with the Inflaton field. But as I understand it, other fields developed from the Inflaton field. So if the ONLY field is the Inflaton field causing Inflation, then there is nothing to stop Inflation.
Hold on there. I though one reason that motivated Inflation to begin with is to explain how the universe has become flat when it was curved to begin with. What are you talking about?
Other fields existed already, however, their energy density was negligible. After inflation the energy density of the inflaton was transferred to the other fields.
You are right that the theory of inflation was motivated to explain the flatness problem, providing a plausible mechanism to make the universe spatially flat. Flatness in cosmology means zero curvature of space, not space-time. However, the question whether particles may or not exist in very curved space-times relates to the curvature of space-time.
Can you give me an idea of what epoc this was? Was this during the time when the universe consisted of a quark soup? Or was it before that when particles received their mass from the Inflaton field? I'm thinking it would have to be before the Standard Model since those fields are of particles which already have mass, etc. And if it is before the SM, then we really don't have a good idea what's going on in that mass receiving interation, do we?
So what are examples of curved spacetime if not near singularity such as black holes and big bangs? I thought Wald was trying to explain the problems with the particle picture associated with these "singularities". But if these situations are not what he is talking about, then I don't know what situations he is referring to.
The start and end of inflation is not known. I assume it can start at any time after the Planck time. The quark soup existed after inflation. See this for more information.
I am sorry but I do not understand what you mean here. Particles or fields is not an issue here. Fields have also mass.
You are right, these are the situations: when the length scale at which space-time curvature is noticeable is comparable to the de-Broglie wavelength of the particles. My intention was just to point out that the fact that energy was transferred to other fields from the inflaton has nothing to do with curvature of space-time.
Can you give me a little story of what's going on in the Lagrangian or Action Integral, or path integral that causes energy transfer from one field to the next? Would it be some way in which coupling constants are used in flat spacetime verses curved spacetime. Any references would be appeciated too. Thanks.
Hellfire.
The Inflationary Period is 10-37 to 10-32 seconds.
I'm not saying that by any means known, but that's what the Standard Model says.
a = e^{Ht}
with H the constant Hubble parameter during inflation. The most simple quantity that tells you something about curvature of space-time is the Ricci scalar:...
I suspect a contradiction in your argument here. If the dominant field was the Inflaton field which exhibits a negative pressure during Inflation, then wouldn't this cause an acceleration in expansion so that the Hubble parameter would not remain constant but would increase with the acceleration in expansion?
If the Hubble parameter is constant, the expansion is accelerating. Try taking the second time derivative of the expression hellfire gave.
Now I'm confused. I thought that accelerated expansion was equivalent to an increasing Hubble constant. At present the Hubble constant is 72km/(sec*Mpc) which means at a given distance space is receding away by a certain emount. But recently supernavae observation show that this rate is increasing with time. So in the future the 72km/(sec*Mpc) value will increase. Isn't that what is meant by "accelerating expansion"?
This supernovae data was used to prove the existence of "dark energy" as the cause of the accelerating expansion. So if the negative pressure of a vacuum energy (dark energy) is what causes accelerating expansion defined by increasing Hubble constant, then how can you have during Inflation both a very high vacuum energy causing acceleration and a constant Hubble constant? Thanks.
Reheating is a rather difficult subject, at least for my level of understanding. What I can do is provide you some basic concepts that may help you to understand some papers.
Lets start with the general expression for the action of a scalar field with some potential in curved space-time:
S = \int \sqrt{-g} d^4x \left( \frac{1}{2} g^{\mu \nu} \partial^{\mu} \phi \partial_{\mu} \phi + V(\phi) \right)
For a massive field one may take:
V(\phi) = \frac{1}{2} m_{\phi}^2 \phi^2 + \mathcal{O}(\phi^4)
Note that the Lagrangian takes over the square of the determinant of the metric for the volume element:
\mathcal{L} = \sqrt{-g} \left( \frac{1}{2} g^{\mu \nu} \partial^{\mu} \phi \partial_{\mu} \phi - V(\phi) \right)
To calculate the Euler-Lagrange equation for the scalar field you should note first that the only relevant derivative is the time derivative and \partial_1 \phi = \partial_2 \phi = \partial_3 \phi = 0 due to homogeneity and isotropy. This means that the Lagrangian reduces to:
\mathcal{L} = \sqrt{-g} \left( \frac{1}{2} \dot \phi^2 - V(\phi) \right)
Furthermore, for an FRW space-time \sqrt{-g} = a^3. You will get:
\ddot \phi + 3 \frac{\dot a}{a} \dot \phi + m^2 \phi = 0
Inserting the definition of the Hubble parameter:
\ddot \phi + 3 H \dot \phi + m^2 \phi = 0
For the time dependence of the Hubble parameter the first Friedmann equation in a nearly flat space (k = 0) can be used:
H^2 = \frac{8 \pi G}{3 c} \rho
For a scalar field:
\rho = \frac{1}{2} \dot \phi^2 + V
If you consider this scalar field to be the inflaton, then these two equations are the starting point to analize reheating. They describe the behaviour of the scalar field in the regime of inflation (negligible kinetic energy) and in the regime of coherent oscillations (similar kinetic and potential energies). In http://arxiv.org/hep-ph/9407247 you can see how the two solutions are obtained.
Furthermore, you can consider two coupled scalar fields:
\mathcal{L} = \sqrt{-g} \left( \frac{1}{2} \dot \phi^2 - V(\phi) + \frac{1}{2} \dot \chi^2 - V(\chi) - g \phi^2 \chi^2 \right)
And, starting from or inserting the oscilatory behaviour of \phi, analize how \chi behaves and energy transfer or particle production takes place. The formalism to analize this is rather complex. Take a look for example to this paper: http://arxiv.org/hep-ph/9704452
Consider:
\dot H = \frac{\ddot a}{a} - \left( \frac{\dot a}{a} \right)^2
and insert there the two Friedmann equations for a flat universe k = 0. If you impose the condition
\dot H > 0
you will see that this implies an equation of state of phantom energy different from the inflationary one.
"Acceleration" refers to the behavior of objects moving with the Hubble expansion. If the physical distance of an objects is given by
d=ax
where x is the comoving distance and a is the scale factor, it will be accelerating (dd/dt2) if
\ddot{a}>0
The Hubble parameter, however, is
H=\frac{\dot{a}}{a}
Try plugging in a variety of time dependences for the scale factor and see how this works out.
A cosmological constant will also lead to a constant Hubble constant. Consider the Friedmann eq. in a flat, pure lambda universe:
H^2=\frac{\Lambda}{3}
If \Lambda[/tex] is a constant, so is H.
d=ax
\ddot{a}>0
H=\frac{\dot{a}}{a}
<br /> <br /> Yes, that helps alot. Thanks ST. So you&#039;re saying that the value of 72km/(sec*Mpc) for the Hubble constant will not change whether there is a dark energy/ cosmological constant or not, is this right? I thought this Hubble constant was measured as 72km/(sec*Mpc) even before the supernovae data when the cosomolgical constant was considered to be zero.
Mike2 said:
Yes, that helps alot. Thanks ST. So you're saying that the value of 72km/(sec*Mpc) for the Hubble constant will not change whether there is a dark energy/ cosmological constant or not, is this right?
The universe we live in isn't purely \Lambda-dominated, so the Hubble constant will continue to decrease with time, but eventually asymptote to a constant value (if \Lambda CDM is correct).
The Hubble constant was approximately measured prior to the SNe results, but I'm not sure why this would matter.
I'm starting to get confused again. I was thinking that the Hubble parameter of 72km/(sec*Mpc) could remain constant and there could still be acceleration in expansion because if the scale factor increase by two, then the rate of change of the scale factor would also increase by two so that the fraction would remain constant. This would mean an increase in the expansion rate with time as the scale factor grows (an acceleration). However, now that I've thought about it, if the Hubble perameter remains constant, then by definition that means that the recession rate is the same for a specific proper distance, even as time increases. And that's not what I understand acceleration in expansion to mean. If the expansion rate does not change and stays at 72km/(sec*Mpc), then the proper distance to the Hubble sphere (where the expansion rate is the speed of light) does not change either. But I understand acceleration in expansion to mean that for a given proper distance the recession rate is increasing with time, and this is equal to saying that the recession of 72km/(sec*Mpc) must increase with time. And this also means that the proper distance to the Hubble sphere would be shrinking with time.
Well, I don't mean to be a pest, but you just got through saying that H^2=\frac{\Lambda}{3}. And I equated a positive cosmological constant to equal acceleration in expansion as I understand it in the above paragraph. If all this is true, then it would seem that the Hubble parameter in the above equation should be zero if the cosmological constant were zero. But this seems inconsistent with a non-zero Hubble parameter measured to be 72km/(sec*Mpc) before the supernovae data when we thought the cosmological constant was zero with no dark energy to drive an acceleration in expansion. Thus my confusion. Any help is appreciated.
This may be a matter of definitions. As SpaceTiger wrote, with accelerated expansion it is usually meant \ddot a &gt; 0.
You may define "accelerated expansion" to be \dot H &gt; 0, but then you are not using the standard definition for it, and furthermore, you must be aware that both are not equivalent.
You can understand this also with the deceleration parameter q = - a \ddot a / \dot a^2. Accelerated expansion means q &lt; 0 whereas \dot H &gt; 0 means q &lt; -1.
Accelerated expansion requires dark energy and \dot H &gt; 0 requires, at least in flat space, a phantom energy.
  • · Replies 19 ·
  • · Replies 153 ·
13K
