Coulomb Gauge invariance, properties of Lambda
The discussion revolves around gauge transformations in electromagnetism, specifically focusing on the Coulomb Gauge condition where the divergence of the vector potential \(\vec{A}\) must equal zero. Participants are exploring the properties that the function \(\Lambda\) must satisfy to maintain this gauge condition.
  • Participants discuss the implications of the gauge transformation equations and how they relate to the Coulomb Gauge. There is an attempt to derive conditions on \(\Lambda\) based on the requirement that both \(\vec{A}\) and \(\vec{A'}\) satisfy the Coulomb Gauge. Questions arise regarding the specific properties of \(\Lambda\) and how to isolate it in the context of the given equations.
The conversation is ongoing, with some participants seeking clarification on the relationship between \(\Lambda\) and the Coulomb Gauge. There is recognition that the original poster's approach may need adjustment to focus solely on the Coulomb Gauge rather than the Lorentz gauge. Participants are actively engaging with the problem and prompting further exploration of the properties of \(\Lambda\).
There is a noted ambiguity in the original question regarding the specific properties of \(\Lambda\) that need to be addressed. Participants are working within the constraints of the problem as stated, which may not provide all necessary details for a complete analysis.
tylerscott
A gauge transformation is defined so as to leave the fields invariant. The gauge transformations are such that [itex]\vec{A}=\vec{A'}+\nabla\Lambda[/itex] and [itex]\Phi=\Phi'-\frac{\partial\Lambda}{\partial t}[/itex]. Consider the Coulomb Gauge [itex]\nabla\cdot\vec{A}=0[/itex]. Find out what properties the function [itex]\Lambda[/itex] must satisfy in order for the Coulomb Gauge to be satisfied.
Lorentz Gauge Condition
[itex]\nabla\vec{A}+\frac{1}{c^{2}}\frac{\partial\Phi}{\partial t}=0[/itex]
[itex]\nabla\cdot\vec{A}=\nabla\left(\vec{A'}+\nabla\Lambda\right)=0[/itex]
[itex]\nabla\cdot\vec{A'}+\nabla^{2}\Lambda=0[/itex]
so
[itex]\nabla\cdot\vec{A'}+\nabla^{2}\Lambda+\frac{1}{c^{2}}\frac{\partial }{\partial t}(\Phi'-\frac{\partial\Lambda}{\partial t})=0[/itex]
and
[itex]\nabla\cdot\vec{A'}+\frac{1}{c^{2}}\frac{\partial\Phi'}{\partial t}=\frac{1}{c^{2}}\frac{\partial^{2}\Lambda}{\partial t^{2}}-\nabla^{2}\Lambda[/itex]
So in order for these to be invariant, [itex]\frac{1}{c^{2}}\frac{\partial^{2}\Lambda}{\partial t^{2}}-\nabla^{2}\Lambda=0[/itex]
So [itex]\Lambda[/itex] must satisfy wave equation.
Now, I feel like I'm missing some of the properties of the gauge, so any help into more insight into [itex]\Lambda[/itex] would be appreciated.
You shouldn't be solving for the Lorentz gauge. The question only mentions the Coulomb gauge. That is the one you need to satisfy. The question says:
[tex]\vec{A}=\vec{A'}+\nabla\Lambda[/tex]
So from here, if you want both A and A' to satisfy the Coulomb gauge, then what does that tell you about lambda? (I'll admit, the question wasn't very specific about what it was asking for).
I don't think I understand what that tells me about lambda... More insight please? Haha
If a general vector V is going to satisfy the Coulomb gauge, then you need:
[tex]\nabla \cdot \vec{V} = 0[/tex]
right, and the question is saying that it wants both A and A' to satisfy the Coulomb gauge. Also they give you the equation:
So using the given information, can you get an equation that contains only lambda (not A or A').
  • · Replies 32 ·
