Coulombs Law - Finding Force When Altering Distance
The discussion revolves around Coulomb's Law and the calculation of the force between two charged bodies when the distance between them is altered. The original poster presents a scenario where the force is initially 1 Newton, and the distance is reduced to half its original size. Participants explore the implications of this change on the force experienced by the charges.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants attempt to understand how the force changes with distance, referencing the inverse square relationship in Coulomb's Law. Some express confusion about how to apply the formula without specific values for charge or distance. Others question the meaning of proportionality and ratios in this context.
The discussion includes various attempts to clarify the relationship between distance and force, with some participants providing insights into the mathematical reasoning behind the problem. There is recognition of the need for conceptual understanding, particularly regarding the implications of halving the distance and how it affects the force.
Some participants note the difficulty in progressing without specific values for charge and distance, while others express a desire for more foundational explanations of the concepts involved.
jemjabella42
If two charged bodies attract each other with a force of 1 Newton, with what force will they attract each other if the distance between them is reduced to one-half of its original size? (The “Newton,” abbreviated by the letter N, is the unit of force in the metric system. This is like the “pound” in the system that you are used to. Contrary to the way that most people use it, the kilogram is not a unit of force but a unit of mass.)
F = k Qq/d2
k = 9 x 10^9
I sketched out my picture then a subsequent sketch with my distance cut in half:
(+)---->1N 1N<----(-)
(+)--> <--(-) I don't know how I am supposed to figure this new force without knowing the Q values or distance! I am only guessing that since the objects are twice as close, this causes the force to double. But honestly, I don't know how to back this up numerically without additional information! Someone please tutor me to understand these concepts better.
F = k Qq/d2
k = 9 x 10^9
The force is inversely proportional to the square of the separation distance.
I still don't understand what this means. So I take d^2 (even though I don't know what d is) and then take its inverse which means d^2= square root of d^2/1?? The thing I have always hated about physics and my brain is I don't see the connections that everyone else sees... How do you know what to do when I am only given 1 value? I don't even understand what is represented by the constant k. Textbooks and handouts are spread all over my desk and I am having such a hard time understanding where all these numbers are coming from. I am really in need of some elementary explanations. I am not trying to be lazy, I have been looking at this question for 2 hours now trying to figure out how to make sense of it.
The subject of proportions and inverse proportions, etc. is usually covered in fairly basic algebra courses. This topic essentially deals with ratios.
The ratio of the new distance to the original is 1 : 1, a.k.a. 1/2
The inverse of this is  ? 
The square of that is  ? 
The ratio of the new distance is 1:1? How is that ratio equal to 1/2?
When I plug this into my equation, how to I solve from:
1N=k(Qq/d^2(1/2)) I know that as my distance gets cut in half, my 1N will expand because of the inverse relationship.
How am I expected to find the new force without a given distance??
After watching about 20 youtube videos, I think I need to take 1/(1/2)^2 and I get 4N as my new force.
I still don't understand how exactly this fits into the equation, but I am going to accept this answer with my lack of conceptual reasoning.
Can someone explain to me what would happen if I were to cut one of my charges (q) in half?
F=k (Qq(1/2))/d^2
When you're given an equation of several variables and constants (here you have F, k, Q, q, and d), and you're asked to determine how one particular variable is affected by a change in another variable, the usual approach is to take the given equation and form a ratio of the new value of the given variable to its original value. All this is done symbolically without needing to plug in actual values.
In your case you have the formula [itex]F = k \frac{Q q}{d^2}[/itex]. You're told that d is being varied in some particular way and you want to know what happens to F. So create the ratio:
[tex]\frac{F_{new}}{F_{old}} = \frac{k \frac{Q q}{{d_{new}}^2} }{k \frac{Q q}{{d_{old}}^2} }[/tex]
Simplify the right hand side by cancelling common terms and that leaves you with:
[tex]\frac{F_{new}}{F_{old}} = \frac{{{d_{old}}^2} }{{{d_{new}}^2} } = \left(\frac{{{d_{old}}} }{{{d_{new}}}}\right)^2[/tex]
Now, the problem says that the new distance is 1/2 the old distance, and that the original force is 1N. So
[tex]\frac{F_{new}}{1N} = \left( \frac{d_{old}}{(1/2)d_{old}} \right)^2[/tex]
Simplify again and you're left with:
[tex]F_{new} = 4N[/tex]
^ Very helpful. Thanks!
9K
