Counterterms in saddle point expansion
  • Context: Graduate
  • Thread starter Thread starter geoduck
    Expansion Point
The discussion centers on the role of counterterms in the saddle point expansion of path integrals, specifically at tree level. It establishes that counterterms are ignored when determining the classical solution, as they only appear later to renormalize divergences. The mathematical necessity of including counterterms is highlighted, particularly their dependence on Planck's constant and the coupling constant λ in the context of λΦ4 theory. The relationship between the perturbative terms and the pure number k is also examined, emphasizing that the size of higher-order terms is contingent on k rather than Planck's constant.
  • Understanding of saddle point evaluation in path integrals
  • Familiarity with counterterms in quantum field theory
  • Knowledge of λΦ4 theory and its coupling constants
  • Basic concepts of renormalization and divergences in quantum mechanics
  • Study the implications of counterterms in quantum field theory
  • Research the mathematical framework of saddle point expansions
  • Explore the role of Planck's constant in quantum mechanics
  • Examine the one-loop corrections in λΦ4 theory and their physical significance
The discussion is beneficial for theoretical physicists, quantum field theorists, and advanced students seeking to deepen their understanding of path integrals and the intricacies of counterterms in quantum mechanics.
geoduck
In the saddle point evaluation of the path integral, at tree level, you plug in the classical solution of the field into the integrand. However, when determining the classical solution, we ignore counterterms. The counterterms only show up to renormalize divergences after a saddle point expansion is made about the classical solution that does not include the counterterms.
Why can we get away with this? It seems mathematically we have to include counterterms in the classical solution for a saddle point expansion to be valid.
The counterterms usually contain Planck's constant, so they should go to zero in the classical limit. But there is an interesting discussion of this issue in http://arxiv.org/abs/hep-th/0405239.
Don't counter-terms have one more power of the coupling in them than bare terms? For example, for λΦ4, I worked out the the coupling has dimensions [\lambda]=\frac{1}{\hbar c}.
So if we write \lambda=k*\frac{1}{\hbar c}, where k is a pure number, then whether your higher order perturbative terms are small compared to tree level depends on the value of the pure number k, and not on Planck's constant.
So for example, the one-loop 4-pt function is \lambda+k*\lambda^2\log\left( \frac{E}{\mu}\right)*(\hbar c).
I assume that (\hbar c) is in the one-loop correction to make the dimensions of the two terms the same. With n-loops I assume you'll get (\hbar c)^n. But you can't say this is small, because you'll also get \lambda^n, which has units of (\hbar c) in the denominators.
  • · Replies 26 ·
10K
