Comp Sci Counting Numbers in Curly Braces in Fortran?
The discussion focuses on counting numbers within curly braces in a Fortran program using a data file named Aggregation.dat. A user seeks help to count only the free molecules represented by single numbers in curly braces, while others suggest alternatives like Python or Tcl/Tk for the task. A sample Fortran code is provided to read the file, identify the aggregates, and output the counts, with modifications suggested for handling varying numbers of lines to skip. The conversation emphasizes adapting the code to dynamically determine how many lines to ignore based on user input or predefined parameters. The thread concludes with gratitude for the assistance received.
Karlisson
< Mentor Note -- thread moved to HH from the technical forums, so no HH Template is shown >[/color]
I have a file Aggregation.dat
6.999e+04 4.50000e+01 2.22222e+00 4.94813e+00 2.50000e+01 1.00000e+00
7.004e+04 4.40000e+01 2.27273e+00 4.99711e+00 2.50000e+01 1.00000e+00
7.009e+04 4.30000e+01 2.32558e+00 5.04732e+00 2.50000e+01 1.00000e+00
MAX 25 MIN 1 AVG 2.325581 STD 5.047315 AGG_NUM 43 AGGREGATES { 0 } { 6 } { 7 } { 8 } { 9 } { 14 } { 63 57 35 70 62 3 31 32 1 24 64 10 39 94 5 68 74 54 2 40 12 28 27 17 } { 21 } { 30 } { 33 } { 34 } { 36 } { 37 } { 41 } { 43 } { 46 } { 52 48 } { 49 } { 50 } { 51 } { 56 } { 59 } { 61 } { 66 } { 69 } { 73 } { 20 91 60 4 71 19 13 58 53 80 25 76 47 93 29 16 45 38 22 92 72 18 65 11 75 } { 77 } { 78 } { 79 } { 81 } { 84 } { 85 } { 86 } { 87 } { 88 } { 89 } { 90 } { 83 15 67 42 82 44 55 26 95 } { 96 } { 97 } { 23 98 } { 99 }
I would like to count only the numbers that are only between "{ }", does somebody have an idea of how to do in fortran?
Please help me.
Welcome to PF!
Is this a homework assignment?
What is your experience with Fortran?
Would some other language like Awk, Perl, Python or Ruby be more suited to the problem?
jedishrfu said:
Welcome to PF!
I am doing research for my MSc with the assistance of simulations, but since I use scripts to some calculations in fortran, for this my option in fortran,
Excuse my writing, I do not speak English.
Do you want to count characters (topic), numbers (first post), digits, or something else?
Take { 23 98 } for example:
1 because it is one bracket pair?
2 because there are two numbers?
4 because there are 4 numeric characters (digits)?
7 because there are 7 characters between the brackets?
Worst case: loop over the whole file, check digit by digit where you are, keep track of what you want to count. I don't know Fortran, but that solution will work in every programming language and does not require more specialized features.
How would you do it in C? Or in Tcl/Tk? Do you know any other programming languages?
Have you done any character file scanning up to now in your learning of FORTRAN?
Each number is related to a molecule. If you have more than one number between "{}" means that it is an aggregate, Ex .: { 28 31 5 }.
If there is only one number in "{}", this molecule is free, Ex .: {19}. I want to count only the free molecules.
I use tcl / tk. To this objective, I have not done any script. But I have done for other objectives.
Hhhmmm...I copied and pasted the input data from above, it looks like this:
Code:
MAX 25 MIN 1 AVG 2.325581 STD 5.047315 AGG_NUM 43 AGGREGATES { 0 } { 6 } { 7 } ...
meaning, the aggregates are found in the forth line of the input file; so, I read and ignore the first 3 lines.
Take the following code and put it in a file named, say, nagg.f90
Code:
program nagg
  character(1000) line
  integer i, j, k, first, last
  read(*,*) line
  read(*,*) line
  read(*,*) line
  read(*,'(A1000)') line
  first = index(line, "{")
  last  = index(line, "}", .true.)
  write(*,*) "Aggregates:"
  i = first - 1
  do
    j = (i-1) + ( index(line(i:1000), "{") + 1 )
    k = (i-1) + ( index(line(i:1000), "}") - 1 )
    if (index(trim(adjustl(line(j:k)))," ") == 0) write(*,*) line(j:k)
    if (k+1 == last) exit
    i = k + 2
  end do
end program nagg
Compile like this:
Code:
gfortran -o nagg nagg.f90
Run like this:
Code:
nagg < Aggregation.dat
It should output the following:
Code:
 Aggregates:
  33
  34
  36
  37
  41
  43
  46
  49
  50
  51
  56
  59
  61
  66
  69
  73
  77
  78
  79
  81
  84
  85
  86
  87
  88
  89
  90
  96
  97
  99
Code:
Code:
program nagg
  read(*,*) line
  read(*,*) line
  read(*,*) line
  i = first - 1
  do
    i = k + 2
  end do
end program nagg
Compile like this:
Code:
Run like this:
Code:
Code:
Aggregates:
  33
  34
  36
  37
  41
  43
  46
  49
  50
  51
  56
  59
  61
  66
  69
  73
  77
  78
  79
  81
  84
  85
  86
  87
  88
  89
  90
  96
  97
  99
I am very grateful for the help. But in fact my input file is much higher, I just put the final. Instead of ignoring just three lines, we would have to ignore 1002 lines in this case. And if this number of lines change occasionally because they depend on the number of steps from my simulation?
Up to this point the script worked just fine, thank you.
There are a couple of simple changes that you can make to the code posted by @gsal:
1. If the number of lines to ignore changes often, take input from the user on how many lines to skip over and run a counting loop (DO ... NEXT) to do just that.
2. If the number of lines to ignore changes infrequently, define a parameter that specifies the number of lines to skip over, again using a counting loop. The disadvantage of this approach is that if the parameter needs to be changed, you need to recompile the code, but if that doesn't happen often, that's not too big a price to pay.
If you are interested in the first line with brackets, look for brackets and ignore the lines until you find one with brackets. Or look for "AGGREGATES" if that is always in front of the aggregates.
good idea.
OK thanks.
