Counting Principles: 15 Ways Explained
  • Thread starter Thread starter Seneka
    Counting
The discussion revolves around the counting principles related to organizing toys into boxes, highlighting confusion over the number of ways to do so without specific information on the toys. Initial calculations suggest using three boxes yields six arrangements, while using two boxes also results in six, and one box provides three ways, totaling 15, which is deemed incorrect. Participants note that the problem lacks clarity, particularly regarding the number of distinguishable toys involved. A suggestion is made that the problem may relate to the "Balls in boxes" concept, which typically involves distributing distinct items into distinct categories. The conversation emphasizes the need for clearer problem parameters to arrive at a correct solution.
Seneka
Q: State how many ways distinguishable toys can be put into three distinguishable boxes.
A: 81
I thought the number of ways would be dependant upon the number of toys.
Since the number of toys isn't given I tried taking into the different ways you can order using different number of boxes.
First situation:
They can use all three boxes 3x2x1=6.
Second situation:
They can only use two boxes so 3choose2 x2= 6
Third situation:
They can only use one box so there are three ways as in you put all the toys in one box.
The sum of these different ways are 15 which isn't correct.
[Moderator's note: Moved from a technical forum and thus no template.]
I'm not an expert on combinatorics or counting-principles, but the problem seems not sufficiently described.
That's what I thought too. I just posted it to see if there was some interpretation of the question to make sense of the answer.
This problem is usually called the problem of "Balls in boxes" , or the number of no negative solutions to ##x_1+x_2+...+x_n =k ##. Haven't you seen this in class?
  • · Replies 28 ·
  • · Replies 29 ·
