How Do You Calculate Covariance and Correlation for X ~ U[0,1] and Y ~ U[0,X]?
To calculate the covariance and correlation between X ~ U[0,1] and Y ~ U[0,X], one must apply the definitions of covariance and correlation. The covariance is given by Cov(X,Y) = E(XY) - E(X)E(Y). The expected values E(X) and E(Y) can be derived from their uniform distributions, while E(XY) requires integration over the joint distribution of X and Y. The discussion emphasizes the need to correctly evaluate these expected values to find the desired covariance and correlation. Understanding these concepts is crucial for solving the problem effectively.
asept
I'm stuck on this problem:
Let X be uniform[0,1] and Y be uniform[0,X]. Calculate the covariance and correlation between X and Y.
thanks
Just apply the definition of covariance and correlation. What are the formulae for both?
Yes correct, and now just apply the formulae for E(X), E(Y) and E(XY). What formulae should you use to evaluate each?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
