Staff Emeritus
2025 Award
- 22,716
- 7,814
https://www.engineering.com/cracks-found-on-boeings-737-ng-pickle-forks/Hairline cracks were detected on a crucial part of the plane called the “pickle fork,” the component that connects the wing structure, landing gear and fuselage. The NG has four pickle forks: two bracket the forward attachment frame and two bracket the rear attachment frame. The lower sections of the components are responsible for transferring most of the wing’s load into the fuselage.
The pickle fork helps manage the incredible torque, stress and aerodynamic pressures on the connection between the wings and the body. The cracks seem to have formed in the outer chord of the rear forks and the behind lying safety straps, just where they pass from the rear spar of the center wingbox to the fuselage side of the aircraft.
The first cracks were found on three Quantas aircraft in September, and other airlines have reported similar cracks since then. About 50 NGs have been grounded worldwide; about 7,000 are in active service and more are in production.
The planemaker, the FAA and affected airlines don’t believe the cracks are an imminent threat to safety. While the stress of the flight cycle does eventually cause metal fatigue, aircraft can still fly with a damaged pickle fork thanks to redundant safety features such as redundant load paths, a “fail-safe” design, or a “safe life” design that minimizes stress levels. However, the pickle fork is a load-bearing component of the wing. “(Failure) may occur in turbulence or heavy landing […] and this could lead to loss of control of an aircraft,” said Steve Purvinas, federal secretary of the Australian Licensed Aircraft Engineers Association.
The structures are considered “safe life” designs, meaning they are supposed to last well beyond the life of the aircraft itself. A pickle fork is designed to withstand more than 90,000 flights worth of takeoffs and landings without cracking.
The problem is, though, that the cracks have been showing up in planes that have carried out less than a third of those projected flights. The three Quantas planes that the Australian airline grounded had only completed around 27,000 cycles. Southwest Airlines found cracks in a plane with about 28,500 cycles, and Lion Air found the damage in two planes that had flown less than 22,000 flights.
Inspections ongoing in 2020
https://www.federalregister.gov/doc...iness-directives-the-boeing-company-airplanes
I was looking for updates and any analysis as to why the pickle forks were cracking before 1/3 of design life. Still looking.
